Detachable Sissy Bar Problem
Old Jun 9, 2010 | 07:14 AM
SkullNeck570's Avatar
SkullNeck570
Stage II
Default Detachable Sissy Bar Problem
I recently bought a detachable sissy bar for my 06 night train (part# 52729-08) and bought the docking kit for it also. In speaking with the dealer he said about a turn signal relocation kit, but my turn signals are all the way back on the fender struts. When I installed the sissy bar it wont lock in because the turn signals are in the way by about 3/8's of an inch. Does anyone know about this?? THANKS!
Old Jun 9, 2010 | 08:33 AM
Ole Coyote's Avatar
Ole Coyote
Thus the directional relocation kit is needed. There are all back there, but still need to be relocated.
Coyote
Old Jun 9, 2010 | 09:18 AM
Double3's Avatar
Double3
You can cut the nub off the mount so it will fit.
There are threads around here talking about it.
Old Jun 9, 2010 | 09:20 AM
Double3's Avatar
Double3
https://www.hdforums.com/forum/6565092-post13.html
Old Jun 9, 2010 | 05:43 PM
The_Dreaded_Moose's Avatar
The_Dreaded_Moose
5th Gear
Let me know if you decide to cut the nub off and how it seems. If it works I just blew way too much money relocating my signal lights.
If it's anything like the Fat Boy Lo I just did it on your signal lights are mounted on two screws at the back even though it seems like one. A relocation kit mounts on one of the bolts freeing enough space for the sideplate to clear them while running the wiring through the mounting bolt itself. Fairly easy to do yourself but I ended up taking the back fender off to make it even easier.
Old Jun 9, 2010 | 06:02 PM
Petegn's Avatar
Petegn
6th Gear
I just ground the nub off the detachable sissy bar brackets, it looks fine and works great... only little issue is the little button to release the lock pushes on the tail light. This was done on 09 Fatboy...
Old Jun 9, 2010 | 10:45 PM
oct1949's Avatar
oct1949
Yea,, son needed to relocate them, as the dealer said....just get the kit for that..
Old Jun 9, 2010 | 10:57 PM
RA51's Avatar
RA51
I have a 06 Night Train with the detachable sissy bar. Just ground the lower corners of the side plates. Mine work fine with no signal relocation.
Old Jun 10, 2010 | 02:06 AM
colonelangus1's Avatar
colonelangus1
i just purchased the docking kit, signal relocation kit ,sissy bar etc and it all works great..the thought of screwing up the powder coating by grinding the tabs off wasnt for me..the relocation kit looks pretty good its well thought out..
orange4
Aug 14, 2016 11:25 AM
stytches
Sep 17, 2012 11:14 AM
Bryanp
Apr 7, 2009 04:05 PM
xbox
Feb 26, 2009 05:41 PM
puddles13
General Topics/Tech Tips
Jan 20, 2007 09:58 PM
