Need quick help with softail fluid questions...
Old Jun 10, 2010 | 04:42 PM
stro1965's Avatar
stro1965
Default Need quick help with softail fluid questions...
I KNOW I bought a service manual for mama's new 2010 Heritage but I'll be damned if I can find anything but my older '05 softail service manual. Have any of the fluid capacities changed since '05? What about the torque values for all 3 plugs? I torqued all 3 at about 18 ft lbs. Hope that's right! I need to get this buttoned up in a hurry so any help is appreciated.
Also, what a stupid place for the tranny drain plug and the tranny dipstick! Just needed to vent about that!
Old Jun 10, 2010 | 04:57 PM
wlbowers's Avatar
wlbowers
dry motor is 3.5 qts. Start with almost 3 run then check. 32oz Primary 32oz trans
14 to 21 inch lbs on torque
Old Jun 10, 2010 | 07:21 PM
jimmers1817's Avatar
jimmers1817
My 08 calls for 2.5 wet fill oil, 32oz tranny, 32 oz primary.
torq specs for all 3 plugs =14-21 ft lbs.
Old Jun 10, 2010 | 08:12 PM
Hollywood Ball's Avatar
Hollywood Ball
I believe the fluid amounts changed from 08-09. I do just what Bowers does (as instructed in manual). Not sure why they would change but they did. Can anyone explain that? Any changes internally?
I always just got with 3 quarts and 32 oz in tranny/primary.
Old Jun 10, 2010 | 08:37 PM
stro1965's Avatar
stro1965
I fumbled my way through it with 32 oz in the tranny and primary and 3 quarts in the engine. Ran it until hot and checked the engine, overfull. Time to find the turkey baster thingy.
Thanks guys.
Old Jun 11, 2010 | 09:26 PM
trapperdick's Avatar
trapperdick
I can't find the trany drain plug on my 07 FLSTC,,,,,,,do the shocks have to come off??
Old Jun 11, 2010 | 09:35 PM
jimmers1817
In between the shocks.
Old Jun 11, 2010 | 09:57 PM
trapperdick
OK thanks, I'll check it out tomorrow.........TD
Old Jun 11, 2010 | 10:21 PM
Mal74's Avatar
Mal74
Instructions with pics here:
http://www.dudeworld.com.au/HOWTO.GEARBOX.HTML
Hair53
Oct 22, 2016 10:55 AM
98glider
EVO
Jun 22, 2013 10:09 AM
128auto
Jun 19, 2011 08:41 AM
rodnock
EVO
Jan 12, 2010 11:30 PM
pr_capone
Apr 26, 2008 11:25 PM
