brake ?
Old Jun 20, 2010 | 10:39 PM
proud1's Avatar
proud1
Question brake ?
when ever you change ur brake pads are you suppose to turn the disc or just change out pads an be on the way also do your signal lights hit the tank when the handle bars turn all the way to either side for fatboy owners how can that be fixed
Old Jun 20, 2010 | 10:49 PM
Kowan's Avatar
Kowan
The rotors shouldn't need turned unless you waited too long to replace the pads that the rotor got scored.
Old Jun 21, 2010 | 12:31 AM
KumaRide's Avatar
KumaRide
You dont turn bike rotors. You should deglaze them though. Sand with 400-600 grit from inside to outside, back and forth, not in circular motion. And clean pistons, pad pins and lube with high temp grease.
http://lyndallracingbrakes.com/service_tech.htm
Old Jun 21, 2010 | 02:13 AM
Bluehighways's Avatar
Bluehighways
As a general rule you do not need to turn ANY rotors Bike or Car just because the Pads are being replaced. As long as the Thickness, Run-Out and Parallelism are within specifications; deglazing (I've always used #80 Grit) is all that is required.
Old Jun 21, 2010 | 02:21 AM
Bluehighways
This site says (among other things); "The further the piston is away from the source of hydraulic pressure the more pressure it requires to move at the same rate as the pistons that are closer to the source"
This violates the very basic laws of Physics. I'd suggest that the author visit (or revisit) Pascals Laws. System frictional losses between the fluid and its container (hoses, lines, calipers, etc.) and the compressibility of Brake Fluid are so insignificant that for all practical purposes they do not exist within the context of a motor vehicle.
Old Jun 21, 2010 | 08:27 AM
KumaRide's Avatar
KumaRide
Here is another write up that should help. Just went through brake problems on my bike. Following the info on these sites fixed the problem.
http://www.moccsplace.com/images/harley/brake/brake.htm
89FLHTC
EVO
55
Mar 16, 2016 07:40 PM
08roadglidejoe
Wheels/Tires
Jul 20, 2010 11:02 AM
lumberjacker
May 20, 2010 06:14 AM
SG 1
Jun 2, 2009 08:44 AM
strickrodt70
Ironhead
Sep 25, 2008 06:18 AM
