How to remove Fatty tank
Old Jul 5, 2010 | 05:52 PM
sandhu22g@yahoo.com's Avatar
sandhu22g@yahoo.com
Cool How to remove Fatty tank
Hell O Brothers
Here i am back with another question about how to remove my 2006 fatboy tank its carb. i have already flushed all the fuel by removing the crossover hose in front of the tank, that connect both the partition, also i have disconnected the fuel gage. all i want to kno is do i have to open the fuel shutoff valve (which is used for turning the fuel at ON, OFF or RESERVE position) also there is a wire attaches to the back of this valve that goes to the carb. need some suggestions
Sandhu
Old Jul 8, 2010 | 09:57 PM
HDTech74's Avatar
HDTech74
you shouldn't need to turn it off it's vacuum operated. the line on the back of the petcock is a vacuum line. just unplug it.
Old Jul 8, 2010 | 11:50 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Also take off the vent tube on the right front of the tank. Take off the dash and either unplug everything or hand it over the bars with some towels to protect from scratching it. Unbolt the front and rear, remove the fuel line at the petcock and take it off. The hardest part is draining th fuel.
Drew
Old Jul 9, 2010 | 06:10 AM
Gman in NC's Avatar
Gman in NC
That's for sure. everything else is pretty much 'cut and dry'. The balance tube in the front is a mess if you don't get the gas out of the tank. Once you do it one or two times you'll get comfortable with it.
High Roller
Mar 14, 2015 07:07 PM
nickd23
Apr 29, 2013 03:47 PM
BlackHwk27
Aug 2, 2009 10:27 AM
HarleyRiderOrlando
Exhaust System Topics
Mar 18, 2006 09:56 AM
Johneb48
Oct 19, 2005 09:40 AM
