First Heritage Darksider~afaik
70 lbs. air popped the old tube. Put a new one in and they had no other problems, again took
70 lbs. to seat beads. I now have a working back brake!!! :cheers:
I'll be used to the different feel in about a day, I think. I've been scraping boards in the neighborhood
to buff off the mold release and even off the bat, she don't slip any at all! Left-right crossover is
virtually nonexistent and I get the "running on rails" feeling cornering over 30 mph.
I tried some object avoidance and the bike handles the same. Weaving has a tall feeling in the center, but of
course, the bike is 1/2" taller for real. I like the gearup of 4mph from the larger tire too. The tire looks like it
belongs in there, with the size of the bike as it is:
Oh, and as a bonus, my speedo is now dead on! It was about 4mph fast. And the softer
rubber is grippy as Jack Benny with a Dollar!
Touchdown! Very cool!
Thanks for breaking the ice on the earlier model Softail's. I understand the frame's are all basically the same on the various Softail's so this tire should fit all of them.
Really looking forward to hearing what you have to say about it after you get a chance to really put some miles on it.
It looks very good on there.
I got just a teeny bit of wiggle at speed, like going down a grooved highway, but less noticable. Took her up to about 90 and it was like sliding down a giant stick of butter! Smoooooooooth...and I notice the bumps thru the front end but the back just swallows them.
It's actually slightly better than I expected, and I took some mountain curves on the floorboards (under 50) just for fun. Wow.
What's this thing gonna be like when it breaks IN??? WOOT!
Here is the ONLY tire I could find save the one suggested by Bob for antique cars, which was thinner. I came up with about 1/4" clearance on the fender left side and 3/8" from the belt, which is PLENTY! 175/70/16 Vredestein Comtrac.
http://www.tiresbyweb.com/p-8480-vre...n-comtrac.aspx
Now, to compare to whatever tire you are running, you will get all necessary info by putting the sizes in this calculator:
http://www.barretire.com/calculator.htm
If you would like to go tubeless, read this thread:
http://mcdarksiders.forumotion.com/g...rims-t1376.htm
Bead are recommended for looks and performance:
http://www.innovativebalancing.com/gallery1.htm
...and if you have metric buddies like I do, send this chart to them, and peruse it yourself for fun to get an idea of bead seat pressures, and so forth for the different tires:
http://darkside.nwff.info/database.php
Like Bob and many others, this is by far the best mod I've ever done to a bike! Now, they say you can scrape pegs in the rain, but that FRONT tire comes to mind, and I for one don't plan on finding out about that trick. I hope all this is enough to get anyone started if they wanna get wild and stop buying tires every few months. I'd put it on even if it didn't get the miles.
I should add this about safety and knowledge: http://darkside.nwff.info/Safety.htm
Valkyrie comparison of CT and MT!!!
http://www.youtube.com/watch?v=QwSSX...watch_response
http://www.youtube.com/watch?v=hIfrF...watch_response
...considering that the tires were maximally inflated at 40psi, I get nervous now at the
lack of contact the MT has!
The tire flexes in a turn, keeping half the tread on the ground. Get behind one and you'll see - we've been watching in the N. Ga. mountains and I'm convinced. You can learn a lot more here:
In that safety link I posted, he mentions why you'll not see these on race bikes - the lean angle is too much. But it works fantastic on our cruisers with their weight and leans. I wouldn't put one on say, a Honda 350. Not enough weight to press the tire.
Oh, last night's ride had ANOTHER surprise, after I rode over Red Top mountain and down the freeway at 80-90 mph and stopped. The FRONT tire was warmer than the back one!
