Gas smell
Old Jul 18, 2010 | 08:53 AM
tk353's Avatar
tk353
i think you can check at night in the dark and use a black light and see the place the fumes come from. it it is the gas cap then get a new one and if there were fumes there is an over flow at the front of the tank and be sure the hose has not come off
Old Jul 18, 2010 | 10:11 PM
PhatBoyBill's Avatar
PhatBoyBill
4th Gear
Default Gas Smell
I had the same thing on my 09 Fatboy. It was the gas cap, even though it clicked like it was tight, It was not on all the way.
Old Jul 18, 2010 | 11:17 PM
Bluehighways's Avatar
Bluehighways
NOT GOOD . . . you need to find the leak . . . .it doesn't have to be much of a leak to generate a lot of smell . . . but a leak is a leak and ya gotta fix it . . . putting out a fire on a bike while riding down the road or just trying to pull over so you can watch you bike immolate itself is no fun.
Old Jul 19, 2010 | 02:12 PM
50ronnie's Avatar
50ronnie
On my 2002 Fatboy Fuel Injected, I had a leak in the gasket that goes between the top plate (under console) and the gas tank (10 bolts). Didn't get it soon enough and clearcoat started to peel from fumes getting under it. Replaced gasket and all is better. Note: Replace the 10 mounting bolts as they have a nylon collar and are NOT reusable.
Old Jul 19, 2010 | 03:30 PM
rscott's Avatar
rscott
Suspect it may be gas cap as last couple of starts no gas smell but I will remove console and check top plate. Don't need no fires
Old Jul 20, 2010 | 11:21 PM
rscott's Avatar
rscott
Gas cap was problem replaced and no gas smell thanks for all replies
saltlick
Mar 31, 2024 09:46 AM
TKDKurt
Oct 8, 2017 09:33 AM
Beverage15
Apr 18, 2013 08:56 AM
lschreiber
Apr 5, 2009 04:27 PM
Finksies
Aug 29, 2007 08:09 AM
