FXSTC Handlebars on a FXST
Old Jul 31, 2010 | 11:10 AM
Knoxville81's Avatar
Knoxville81
Default FXSTC Handlebars on a FXST
Im looking to buy an 07 FXST my question is this, will the stock handlebars off a FXSTC fit directly on a Standard that currently has all the stock parts on it? Does anyone know if the wiring and clutch and brake cable are all the same length?
Old Jul 31, 2010 | 01:20 PM
flstcbob's Avatar
flstcbob
If you're keeping the stock pullback risers, you will need a longer brake line. Everything else will be a stretch, but do able. With short risers, it will be a perfect fit.
Old Jul 31, 2010 | 01:22 PM
Knoxville81
Thanks for the reply, i would actually use the stock risers from the FXSTC as well.
Old Jul 31, 2010 | 05:16 PM
eddyp's Avatar
eddyp
Ive got the FXSTC set up on my 2006 standard, best mod Ive made so much more comfortable, you will need a new front brake line the rest of the cables will be fine. Once I had the FXSTC I found they were so nice I swapped them for the chubby versions
Old Jul 31, 2010 | 07:26 PM
Knoxville81
Awesome, thanks for the reply. Do you happen to know how much over stock you went with the brake cable?
Old Aug 1, 2010 | 04:55 AM
O6FXST's Avatar
O6FXST
I had the dealer do the exact same thing to my 06 FXST. They used the stock cables which are plenty long enough and a 6" electrical wiring extension, but I can't remember if they had to replace the brake line. I like them a lot better than the stock bars.
Old Aug 1, 2010 | 08:47 AM
eddyp's Avatar
eddyp
Ive just measured and its 47 1/2 inches including the banjos, If I were to do it again I would add 1/2 inch so i could get it closer to the curve of the bars
Iamjustifyd
Jun 30, 2018 08:27 PM
TRIED N TRUE
Oct 16, 2013 07:08 PM
treynolds155
Apr 12, 2009 04:49 AM
hddave2
Oct 6, 2007 06:35 AM
drumer66
Apr 10, 2007 02:09 PM
