Timing cover torque specs
Old Aug 3, 2010 | 06:50 PM
Malingerer's Avatar
Malingerer
Default Timing cover torque specs
Does any one know the torque specs on the timing cover bolts.Cant find it in the manual anywhere.Dont know if there are any .Talking about the one on the right side of the bike with the 5 screws not the inspection timing cover on the left side.Thanks Tom
Old Aug 3, 2010 | 06:56 PM
WFA's Avatar
WFA
Originally Posted by malingerer
does any one know the torque specs on the timing cover bolts.cant find it in the manual anywhere.dont know if there are any .talking about the one on the right side of the bike with the 5 screws not the inspection timing cover on the left side.thanks tom
no specs that i'm aware...don't need 'em. It covers nothing requiring a seal.
Old Aug 3, 2010 | 07:02 PM
BLKnCHRME09Deluxe's Avatar
BLKnCHRME09Deluxe
90lbs of torque is needed!....lol....jk....its a empty stash spot thats all. Hand tight and your golden...good luck
Old Aug 3, 2010 | 08:02 PM
Malingerer's Avatar
Malingerer
Thanks fellas Thats what I thought.I'm just picky and try to do everything to factory specs.Theres a lot of coin going into our bikes and just want it to be done right. I'm sure you know how that goes
Old Aug 7, 2010 | 09:59 PM
MotorDog69's Avatar
MotorDog69
Former Sponsor
hand tight, just dont over tighten those screws, i didnt see it in the manual either...
John
Old Jul 20, 2022 | 02:18 PM
Wave Boreal Forest's Avatar
Wave Boreal Forest
Holy thread resurrection but these are prone to breaking. Spent the evening trying to drill one out. There is no seal so road grime gets to the screws and they snap from the neck. This doesn't matter if you don't plan to switch the cover of course but you could loosen and clean every once in a while.
The real pita are the derby cover screws since they seal and your day is screwed if one snaps.
Old Jul 20, 2022 | 02:43 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Give us a clue as to the model year.
Old Jul 20, 2022 | 02:47 PM
Rob Roy's Revenge's Avatar
Rob Roy's Revenge
For the #8-32 pitch screws 18 to 30 Inch / Pounds or 2.0 to 3.4 Newton / Metres of torque will do the job nicely.
A good idea is to replace the torx button head screws with cap heads as they have a larger socket.
Old Jul 20, 2022 | 05:50 PM
hattitude's Avatar
hattitude
I usually don't even read old threads, but I just happen to have an HD reference for this question...
HD calls that cover, the "Timer Cover"....
While HD doesn't list a torque spec in the Service Manual for the timer cover screws... They DO list a torque spec for them in the install instructions for all the accessory timer cover kits they sell...
The official HD torque spec for the timer cover screws is 15-20 inch pounds (1.7-2.3 N-m)...
cj24
Jul 3, 2019 12:24 PM
Blvfisc
Jul 22, 2016 04:19 PM
TerryM
May 22, 2007 12:41 AM
Caston
May 10, 2007 09:26 AM
vnvjames
Aug 8, 2006 12:50 AM
