Progressive drop in spring kit question
Old Aug 6, 2010 | 10:09 AM
Malingerer's Avatar
Malingerer
Default Progressive drop in spring kit question
Looking into installing the progressive drop in front fork springs today(kit # 10-2003) on my deluxe.Looks easy but the directions with the PCV spacer are unclear.They say to cut the spacer at 3". Okay cool but how much of a drop does that give you.I am looking to go the full 2 ".It also says dont go 1" more or .50 " shorter than the recommended 3 ".Will this lower it more if you do or maybe just change the preload? Thanks Tom
Old Aug 6, 2010 | 10:23 AM
Malingerer's Avatar
Malingerer
Sorry One more question what size socket do I need to remove the fork cap Thanks in advance Tom.
XARAN's Avatar
XARAN
The reason that they dont want you to go more than 3" is spring preload. The big problem with the Drop In Kit is soft , soggy fork rebound. The more you lower it the less preload to the springs and the softer your ride and rebound are. Cutting more will lower the bike more but your spring preload will get progressivly softer.
If you call the tech line for progressive the guy I talked to still reccommends the original kit to lower, it will give you a true 1 or 2 inch drop and you can properly preload your spring tension to you riding style and weight. Also the original kit is less $ 89.00 from Eastern Cycles on E Bay and with a FL Softail you need to at least loosen the fork legs to slide them down so its not much more to remove the sliders and do the whole job.
Old Aug 6, 2010 | 10:36 AM
Malingerer's Avatar
Malingerer
Thanks for the help.When I called progressive the tech sold me on the drop in kit go figure.Guess I'll stick with the 3 " I am also switching to the screaming eagle heavy fork oil hopefully that helps stiffen it up a little.I got my drop in kit from Easteren performance as well 95.95 to my door.And 379.00 for
my 422's If you call them in person they always seem to do a little better than ebay.
Parts Giant
Parts Giant
Apr 17, 2019 08:58 AM
UltraDune
Mar 19, 2012 01:31 PM
Fabrikator
Dec 31, 2011 05:15 AM
vasya100
May 23, 2011 10:17 PM
badbs101
Jun 23, 2010 09:19 AM
