LED Bolt-FX Install (Need help tapping tail light wires...)
So I have some of those LED Bolt-FX things that allow you to light up your license plate and I'm trying to figure out how I need to splice/tap/whatever the wires from the LED Bolt-FX to the existing tail light wires.
The LED lights on the bolts for the license plate will basically be running lights so they are always on. Do I simply tap into the red wire going into the tail light bulb with the red coming from the LED? and then the black from the LED into the black that looks like it goes into a ground behind the tail light bulb? Is that blue the wire that makes the brake light activate, making the light brighter than the standard running light?
Since I need to splice both the left and right LED bolt into the tail light wires, where's the best place to do that? Should I splice them both next to each other on the left side where the wires come out of the black casing by the bulb or is it better to do one there and one up above or something?
Also, the wires from the LED bolts aren't covered by a black casing or anything...do I need to worry about them being exposed as they are? Do I need to get a cover or something to protect them? Here's how it looks now...
Do I need to worry about any kind of load balancer or anything like that? I know from what I've read if you swap out your bulbs for LEDs I'd heard some people saying you need a load balancer...
I got some of those quick splice things from Advanced Auto that I planned on using to connect the wires together... are these ok?
Thanks...trying to save the $$ by doing this myself rather than paying a shop 30 minutes labor.
The quick splice you show is what I used when I added my LED plate frame.
I just tried one of them out with some of the excess wiring that was in the package connected to the little battery unit for display and it didn't puncture through to the wire since they are so thin...
So I think I need to get smaller ones...
You can get T-taps at most local auto stores. I just used a probe to find the running light wire.
