Tightening mirrors
Old Aug 13, 2010 | 11:04 PM
SalsaNChips's Avatar
SalsaNChips
Default Tightening mirrors
My 2002 FXST has the standard black finish short-stemmed HD mirrors. I have started to have a problem where the left mirror will sometimes change position on the ball-type mount that holds the mirror. That is, the position of the mirror will change and I have to re-adjust it. Seems to happen most under heavy acceleration, like the vibration is getting to it or something.
Obviously, the tension on that ball mount that holds the mirror isn’t sufficient. I’ve looked and there doesn’t seem to be a way of increasing that tension.
Wanted to see if anybody knows of a way to accomplish this (short of buying new mirrors).
THX
Old Aug 14, 2010 | 12:54 AM
DocJ's Avatar
DocJ
I had the exact same problem about two or three months ago. As it is, I'd have to go look at my bike to remember the fix, but it took less than 10 seconds after explaining the situation to a tech at the local dealer. He just told me what to do and I did it.
Why isn't my memory working?!
Hopefully, somebody else can be more helpful. I just wanted you to know thus is an easy fix and certainly nothing to be worried over.
Old Aug 14, 2010 | 06:31 AM
SalsaNChips
I tried rotating the mirror a couple turns around on the ball mount to see if that would tighten it up but it didn't. Just guessing, have no idea if that would make a difference. I'll dig into the service manual and follow up if I find anything useful there...
Old Aug 14, 2010 | 09:10 AM
xwhyz1959's Avatar
xwhyz1959
Are there 2 little screws on the back of your mirror on either side of the stem?? If so, tighten them.
Old Aug 14, 2010 | 09:42 AM
Mal74's Avatar
Mal74
Looking at his other pics there's no screws on the mirrors. I have the same mirrors, except chromed, on my Heritage. They aren't loose but I'm interested in knowing the answer to his question also.
KISS
Old Aug 16, 2010 | 07:43 AM
DocJ's Avatar
DocJ
Sorry to take so long on getting back here. I've checked my mirrors out, and cannot remember the fix whatsoever. I'm surprised nobody has been able to help you out here, as this was an easily fixed problem for me.
I guess at this point, my only recommendation would be to ask a mechanic at an indy shop, or go to the dealer and ask the techs there.
I'm curious if there would be anything on this in the service manual...?
Otherwise, just forget about it and use this as a good excuse to buy some NEW styling mirrors.
Old Aug 16, 2010 | 07:50 PM
olongapo1's Avatar
olongapo1
Had the same problem with the stock mirrors on my NT. No adjustment screws, just a ball and socket which over time loosens up.
I eventually;
(1) properly positioned them.
(2) carefully removed them from the handlebars.
(3) laid them flat on a bench and soaked the ball and joint area with super glue.
So far, they have held their position but I expect vibration will eventually brake the glue.
Rurlndum
Sep 20, 2017 09:44 AM
HemiOrange
Jan 29, 2014 08:44 PM
Bedore
Jun 13, 2010 08:54 PM
luvmy03spt
Jan 19, 2010 04:56 AM
nmer
Screamin Eagle CVO Models
Apr 27, 2007 12:36 PM
