Hey guys - I have a 2007 Deuce. Ordered a pad for the rear brake lever. Wrong one I think. When I was looking at the stock pedal - just rubber - Does not seem to have a hole in the metal under the rubber.
I was thinking of cutting the old rubber off and drilling a hole in the metal to accommodate the new pad ?
Has anyone replaced their pad ? trying to add a pad with an iso look ?
I had same on my Crossbones and read on here that they were tough to get off.
Worked it out, big flat screwdriver and big spray of WD40 it came off in a minute with a bit of gentle levering. You shouldn't need to cut it off. lube the key
