primary whine
Old Sep 19, 2010 | 04:44 PM
Sash302's Avatar
Sash302
Default primary whine
I guys,I just return from 1500 miles trip,I know this the whine is coming out of the primary side of the bike,increase the rpm whine goes with it, any ideas?
O the bike have only 6500 miles on it, 2009 nighttrain.
any comments are welcome
Old Sep 19, 2010 | 05:08 PM
djl's Avatar
djl
Does it whine in gear and under load and in neutral unloaded? or does the whine change if loaded or unloaded?
Old Sep 19, 2010 | 05:15 PM
Faast Ed's Avatar
Faast Ed
If you can sit in neutral and hear the whine, and it gets louder with the rpm,...... It sounds like your primary chain adjuster clicked-up a notch or two too much.
A too tight primary chain will have the exact symptoms I described.
Old Sep 19, 2010 | 05:33 PM
Sash302's Avatar
Sash302
O.k now that is very good possibilities,because about 50 miles from my house I was stopped on the side on the busy freeway,so I have to take of like a bat from a hell to jump back on the freeway,that might happen right than..so can something go wrong if that's the case?
Old Sep 19, 2010 | 06:03 PM
Tired_bird's Avatar
Tired_bird
its fairly easy to pop the inspection plate off and see how tight the chain is. Just sounds hard but anybody can do it. I don't know what the chain travel limit is supposed to be on those years though. I'm sure someone on here has it memorized.
Old Sep 19, 2010 | 06:19 PM
Sash302's Avatar
Sash302
There is no inspection Plate on the newer bikes
Old Sep 19, 2010 | 10:46 PM
Tired_bird's Avatar
Tired_bird
Holy Smokes, for real? That sounds like the dealer trying to make it harder for the normal guy to work on his own bike. So you need to take the whole primary cover off to look at the chain? did that start when they changed to fuel injection and a six speed transmission?
Old Sep 20, 2010 | 03:46 AM
story808's Avatar
story808
Sash... Maybe the newer ones like yours have that auto tensioner? You may wanna reseach that. Seeing that the miles are so low maybe you should take it in under the warranty?
Old Sep 20, 2010 | 09:45 AM
tk353's Avatar
tk353
I use Bel Ray for the trans and no wine or clank and I can find neutral. I use Motor FactoryŽ Primary Case Lube in the primary. because Amsoil has gone up so much I just switched to Mobil 1 for vtwin and it works as good. I have 58,000 miles in about 3 years and it runs great and no debris in the oil changes.
http://www.belray.com/consumer/product.fsp?pid=1338
http://www.customchrome.com/dcm/cc/view.asp?mfoil.html
Old Sep 20, 2010 | 11:56 AM
Sash302's Avatar
Sash302
You are right dude, I already contact the dealer, the dude was cool he say to bring the bike in and they will take care if anything is wrong.
