Cross Bones adjusting front fork?
Old Oct 6, 2010 | 07:52 AM
Crossb0nes's Avatar
Crossb0nes
To torque the rocker arm spherical bearings properly you need a appropriate rated torque wrench, and the manual says preferably a dial gauge or beam type one. I strongly suspect (but dont 'know') that this bit of maintenance directly influence how hard or soft the suspension is ... I know mine was locked rigid for the first 500 miles until it was adjusted properly ...
It one of those jobs I'm not going to do myself .... I'd wait til you got the manual.
The rocker arms are the short straight bits of iron that let the wheel rotate up and down .....
Old Oct 6, 2010 | 11:09 AM
JayOhh's Avatar
JayOhh
Ok. So as I'm looking for some info about this fork online, I discover it's been a recall on a bolt or something for the Cross Bones` fork. How do I know if this is done to mine, or if it's something I have to get done before any more riding?
Old Oct 6, 2010 | 07:44 PM
Rakthi's Avatar
Rakthi
If your bike has been at the dealer after the recall it should be done. They just replaced the bolt holding the fender/brake on the left with one that has a cotter pin to prevent it from backing out. You can go to the HD website and plug in your VIN number. It will show if there is an outstanding recall on yr bike.
http://www.harley-davidson.com/wcm/C...bmLocale=en_US
Just check to see if the bolt has a cotter pin through it see picture. That's the only thing. If it doesn't you can still ride, just check to make sure the bolt hasn't backed out.
I know bike is dirty, but is rainy season here ...
Old Oct 7, 2010 | 03:07 PM
JayOhh's Avatar
JayOhh
The pin is in Guess it's all good. Thanks..
matte
Jul 3, 2019 09:54 PM
jmn1960
Oct 4, 2015 05:19 AM
jlilnc14
Aug 22, 2012 07:16 PM
dwatkins
EVO
Apr 28, 2012 06:45 PM
cmoran3
Jun 27, 2008 09:50 AM
