SE Air Cleaner
Old Nov 21, 2010 | 05:42 AM
bucaman's Avatar
bucaman
Default SE Air Cleaner
Possible stupid question?
94 Heritage I just recently purchased was listed as having the Screaming Eagle Air Cleaner set up. It looks like a stock set up to me.
What can I look for to verify?
Came off a dealer lot so I assumed they new what was on it.
My first EVO. So far I am loving it.
Thanks.
Old Nov 21, 2010 | 06:44 AM
jtsteiert's Avatar
jtsteiert
Remove the stock cover and the S/E air filter will be behind it. I also bought mine from a dealer used and didnt find out I had a S/E air filter until maintenance time when I went to change the air filter.
But it mounts in the same filter housing as the stock filter does.
Old Nov 21, 2010 | 07:43 AM
Gman in NC's Avatar
Gman in NC
If it's an SE the backing plate and filter are 'round'. If it's stock the backing plate is football shaped like the cover and the filter is not round.
Old Nov 21, 2010 | 10:22 AM
Mr. Lucky's Avatar
Mr. Lucky
Not on an EVO. I have an EVO cover in my sig pic.
Old Nov 21, 2010 | 02:09 PM
bucaman's Avatar
bucaman
So if I am understanding you all, It is just the cleaner. I assumed it was more than that...backing plate and such.
When I see a kit for $125.. is that it? Just the filter and cover and ring?
Old Nov 21, 2010 | 02:44 PM
Mr. Lucky's Avatar
Mr. Lucky
It's the backing plate and the filter, but does not include the cover. In the case of EVO, you can still use the stock cover.
Old Nov 23, 2010 | 06:49 AM
Gman in NC's Avatar
Gman in NC
It is a new backing plate, new cylinder breather tubes/bolts, new rubber breather tubes and an air cleaner. It's a pretty big difference. Then you can put a lot of different covers back on including the stock one.
NBADER1979
EVO
May 14, 2019 11:59 AM
TravisD27
Apr 24, 2018 04:23 PM
tmcgeesr
Aug 9, 2009 04:17 PM
Abnmarine
Jan 3, 2007 02:31 PM
rhinoevans
Jul 10, 2006 12:42 PM
