Springer riser question
Old Nov 30, 2010 | 08:41 PM
Lttleric's Avatar
Lttleric
6th Gear
Default Springer riser question
Hello there,
looking for a little help with changing the risers on my springer(96 bad boy FXSTSB) I bought it with these http://www.jpcycles.com/product/5000255 risers already on it and I want to know what I need to swap over to standard style harley risers. I dont have any of the original parts to reference. The dealer wants $250 for all the stock parts. what are my options?
any help is appreciated!
Old Nov 30, 2010 | 08:52 PM
brettnbama's Avatar
brettnbama
If you want standard non-springer specific risers, there are adapters you can get to make the changer. Look for Springer riser stud adapter or something
Old Nov 30, 2010 | 10:36 PM
Lttleric's Avatar
Lttleric
6th Gear
Any idea if the Crossbones studs and risers will bolt onto the Badboy?
Old Dec 1, 2010 | 06:12 AM
brettnbama's Avatar
brettnbama
I would think so....
Old Dec 1, 2010 | 07:51 AM
hspring03's Avatar
hspring03
Crossbones, Springer Classic, Heritage Springer, bad boy all used the same risers. Only difference is that FX's were 4". The FL's were 3"
Carlini sells adapter plates to put Standard front end risers on the springers
Old Dec 1, 2010 | 11:22 AM
smketr7139's Avatar
smketr7139
I just went to my local auto machine shop they sell the bolts there. J&P wants $15 for the set I paid $2 each. They are threaded on each end, I think they are 1/2"x20? screw one side into the bottom of your standard riser (with locktite) and then screw the riser into the top of your front fork. I had to use a cheater bar to get them screwed in all the way so I wrapped it with a shop towel to protect the chrome riser. Gives it a much cleaner look than what you are running now IMO check out my pics I think you can get a good view of mine.
Old Dec 5, 2010 | 09:34 PM
Lttleric's Avatar
Lttleric
6th Gear
I think I figured it out. I bought some through bolt risers and studs from J&P. I also looked at the top triple tree form Carlini's, but It is chrome and my springer is black. So I will wait on the top plate to see how the stock type stuff looks.
Thanks for the help
dcdr
Oct 2, 2015 12:51 PM
TruckerXbones
Apr 2, 2013 07:10 AM
wydglydrydr
Mar 12, 2011 09:51 PM
pbasz
Jan 2, 2009 03:37 PM
jeffwest5599
Sep 14, 2007 03:49 PM
