i'm going to put ricor intiminators on my '10 FXSTC and need to know the spec on how much fork oil is needed, can anybody tell me what the harley softail manual says about this?
thanks for your help
Bolt
Be sure to use the recomended weight oil if you did not order it with your Intiminators. If you are not sure, give Brian a call to verify. Stock Harley oil or anything heavier than recommended will not work as well.
had some other stuff to do and didn't get started until after lunch, when i realized that i had to remove forks (unlike when i did this mod on my sporty) to do the intiminators, i decided to wait until i bought the repair manual...
so i just put the arlen ness 3" extended forwards on today, just wish it was warmer so i could go riding!
