Softbrake Plate Bracket Install...How To
I have a couple of mods I did that might help (might not) but here they are:
1. I drilled an extra hole in the license plate bracket to run the wiring behind the bracket
on the top part of the plate section, in line with the lic. bolt holes
2. Instead of filling in the two unused holes (from original plate bracket) I put silicone on the heads of them and put them in their plastic bracket. Let it sit overnight, and then I just put the whole plastic cover under the fender and bolted the right back in place. Might be easier just to silicone the holes
