raked cups
Old Oct 1, 2006 | 03:20 PM
deuce dude's Avatar
deuce dude
Default RE: raked cups
there is a few points to consider when using the cups.......
1-you need to have a little fork stop block welded in, no big deal and really easy to do.....you can also get an internal stop....
2-the fork lock didn't work afterwards...not a big deal to me as i use a disc lock.
3-they move your triple clamps away from each other an inch os so....i liked it better afterwards though
Old Oct 1, 2006 | 03:22 PM
deuce dude's Avatar
deuce dude
everything is stock except for the cups....rides great!
ORIGINAL: mopar360
Deuce Dude, did you change the lenth of the forks or the tripple trees or is everything else stock on the front end, no handleing problems, I'm interested in the same thing for my 2001 Softail standard.
Butch
Old Oct 1, 2006 | 03:25 PM
deuce dude's Avatar
deuce dude
you drive or cut out the old bearing races and the raked ones press into the place where the race used to be.......pretty simple really. the hardest part is getting the old bearing races out of the stock neck, i used a dremel.
ORIGINAL: 20NightTrain03
ok now we are getting somewhere!
i went to the perse calculator and put in the raked cups as if the neck was raked 3*
comes up no good with just a little too much trail
did the same with 3* raked trees and comes up perfect
did it the calculations with 3* cups AND 3* trees also comes up OK
now i am not looking for anything radical like 7* or 5*...........so i feel safe trying 3*
how do you install the cups? just drive out the old ones?
do i need to change anything with my fork lock or fork stops if i am using just 3* cups?
also can somebody describe the front fork fall away test for me? i have both service manuals but they are a little vague
Old Oct 1, 2006 | 03:48 PM
Joshua Chane's Avatar
Joshua Chane
Heck ya! THis is a great thread! I love the info!!!
JOSH
Old Oct 1, 2006 | 04:59 PM
deuce dude's Avatar
deuce dude
i can help a lot on this project, just let me know........
Old Oct 1, 2006 | 06:39 PM
20NightTrain03's Avatar
20NightTrain03
can i use a c-clamp and a block of wood (with the appropriate driver on the cup of course) to press them in?
Old Oct 1, 2006 | 07:38 PM
deuce dude's Avatar
deuce dude
sure can....i tapped them in real slow using a big socket.....
Old Oct 2, 2006 | 01:25 AM
20NightTrain03
nice, looks like i will have a nice winter project
that and a new front wheel cuz my tire is wearing out, so might as well do them both at the same time
Old Oct 2, 2006 | 02:59 AM
deuce dude's Avatar
deuce dude
its an easy project, just a weekend or perhaps a day.....you will need to press out the old stem from the bottom triple clamp, its in there real good!
Old Oct 2, 2006 | 03:18 PM
blueduece's Avatar
blueduece
DD, can you take a close up pic of the work you did for the rake cups?
Thanks
BD
