stupid wide glide question
Old Dec 26, 2010 | 08:42 AM
82flh's Avatar
82flh
Default stupid wide glide question
i have my bike on lifts i want to mount my front fender close to the tire does fender travel with tire when bouncing? i cant tell its on lifts my fender mounts are on legs dont wanna screw up anyone with a stock softail with wide glide check it out for me
i feel so stupid right now.........lol
Old Dec 26, 2010 | 09:03 AM
fcsallan's Avatar
fcsallan
the fender mounts to the same part as the tire. They move together in relation to the frame, so you should be able to get it to a tight clearance without issue.
Old Dec 26, 2010 | 10:25 AM
Mr. Lucky's Avatar
Mr. Lucky
What fscallan said... just allow for slight tire growth when the tire is warm.
If it's going to drag on the tire, it will usually happen at the inside arc where you can't see it. Best to tape a fat electric cord or skinny hose to the tire, using that to mock up your fender distance. Then drill new holes or make your current ones eccentric. See pic below of my Night Train (which comes with Wide Glide front end) to see just how tight is possible.
Old Dec 26, 2010 | 10:29 AM
dex82's Avatar
dex82
yup, fender will move with tire.....it's mounted on the sliders. just remember tire will expand slightly when it's warm
Old Dec 26, 2010 | 12:32 PM
Lockman's Avatar
Lockman
Also, consider the tread on a new tire vs. your current tire. Leave enough for a new replacement.
Old Dec 27, 2010 | 06:56 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Don't do it!!!
Its more work than its worth and you'll probably be disappointed with the look.
Reason is that the fender is made with an arc in it that matches the tire at the distance it is from the axle.
If you move the fender closer to the tire its going to be close in the center, but farther away at each end.
The best way to get the fender closer all the way around is to either get an aftermarket one or order one from the dealer for an 09 (maybe an 08) and up bike as they are mounted much closer than the 07 and down bikes.
nosparkoflife
Nov 25, 2013 03:36 PM
Steel Steed
Sep 4, 2011 09:59 PM
ConnMan
Mar 20, 2011 02:56 PM
myxcape
Apr 21, 2009 08:56 PM
jsbridgew
Jul 8, 2008 12:21 AM
