Question for those with Lowered Front Suspension
Old Jan 4, 2011 | 05:38 PM
mjohnston66's Avatar
mjohnston66
Default Question for those with Lowered Front Suspension
Okay all you lowered front suspension guys & gals, I'm in need of some advice. I have an '05 Deluxe with 21" front wheel, lowered 1" with a progressive drop in kit. Looks killer but honestly, ride got a lot stiffer over stock ride, especially over the nasty bumps & potholes.
My question is, are there any other spring kits out there that provide a stock/better than stock ride for the front end? I plan on going to the shotgun air ride for the rear eventually so that should set me up nicely out back. I just want something that can match the ride I will eventually have in the back.
Old Jan 4, 2011 | 05:59 PM
ramhunter9's Avatar
ramhunter9
I also have the 2" progressive in the front , with a Hi Lo in the rear ... havent gotten a chance to ride yet ... snow ... but I will let ya know .
Old Jan 4, 2011 | 06:16 PM
turbois417's Avatar
turbois417
Hey Bro did i see you at Victoria Gardens in Rancho recently?
Old Jan 4, 2011 | 08:11 PM
mjohnston66
Nah bro, must have been my evil twin. I'm down south in the 619. I did ride up to the Mooneyes show at Irwindale last month.
Old Jan 4, 2011 | 08:51 PM
BLKnCHRME09Deluxe's Avatar
BLKnCHRME09Deluxe
Ride is gonna be stiffer/suffer the lower you go. You traded looks for comfort.. Use heavy wieght fork oil to help prevent bottom outs.
I used to have the Arlen Ness dampners which were terrible and changed to Progressive springs.
Your not gonna find a mushy stock feeling ride unless is lifted back to stock.
Old Jan 5, 2011 | 12:43 PM
mjohnston66
Thanks all for the replies so far....I was reading another thread this morning that mentioned Ricor Intiminators which sounded promising. Who has experience with these and could this be a solution?
I thought the good Dr. may have mentioned installing these in one of his threads. Will these work with a drop in kit?
Old Jan 5, 2011 | 01:32 PM
beaureed445's Avatar
beaureed445
You have the best kit on the market.
Old Jan 5, 2011 | 01:55 PM
SMF's Avatar
SMF
I think my handling became better but I did my drop in kit and 21" install at the same time also running the progressive
Old Jan 5, 2011 | 03:13 PM
MADDOG808's Avatar
MADDOG808
Aloha All,
MY 2008 Deluxe is running a 21" Front and 18" rear (Fat Dadday 50's) I've installed the progressive drop in spring kit on the front end and dropped the full 2"s. And also installed the progressive 422's and dropped the rear 1 3/4". My front ends feels firmer. But imo handles better. As for the rear, yeah it's a little stiffer ride but it is tolerable. Not to mention the bike looks sick lowered.
If you only dropped the front 1", try going the full 2"s. I sure you'll like the feeling. Plus with that 21" front wheel up front. It will be bring the front end back down to stock height. Taller tire up front, raises the bike and changes your rake.
Attached Thumbnails Question for those with Lowered Front Suspension-sunny-day.jpg
Old Jan 5, 2011 | 08:27 PM
j33ptj's Avatar
j33ptj
I have the drop in kit for the Rocker, initially installed with the spacer uncut, and the ride was very uncomfortable. I tried removing the spacer completely, but that made it way to soft.
In the end I cut 1" of the 3" spacer and that gave a smooth nice ride again!!
So if its too stiff, cut a bit of the spacer.
Robert
Vito Orso Basile
Nov 25, 2016 02:18 PM
Nbdzhro
2014-2024 Touring Models
Feb 22, 2015 08:34 PM
gauravkachru
Apr 27, 2014 02:07 AM
Kern
Jul 3, 2008 11:00 AM
ShockwaveTXB
Jun 28, 2008 03:17 PM
