Changing fork oil
Old Jan 22, 2011 | 11:02 AM
CHOPPIN' CHARLIE's Avatar
CHOPPIN' CHARLIE
Cool Changing fork oil
Changing fork oil on "09 Heritage and will us new washers, top and bottom, and new drain plug screws as directed. Do you use loctite on top and/or bottom plugs ? Factory had 'em way over torqued, I think. Had a hard time locating a 1 & 3/8" tool for top bolts. Marked one top bolt so will dress "em up with the 3 piece hot topper kit.
Old Jan 22, 2011 | 11:24 AM
Mr. Lucky's Avatar
Mr. Lucky
No. If anything, I would use anti-seize (in fact, I did when I just changed my sliders and fluid recently). The crush washer (use new ones) on the drain screw will both seal and inhibit back off, and the tube caps are under tension so they are not going anywhere.
Old Jan 22, 2011 | 01:16 PM
Twofields6's Avatar
Twofields6
+1, just changed mine and used loctite.
XTonerman
2014-2024 Touring Models
17
Nov 19, 2021 04:39 PM
ggruber
Sep 29, 2014 01:19 PM
PPBART
May 19, 2011 12:01 PM
CHOPPIN' CHARLIE
Jan 24, 2011 06:37 PM
kkiley
Mar 21, 2010 07:47 PM
