Installed the Power Vision tuner
Old Jan 27, 2011 | 07:40 PM
McRider's Avatar
McRider
Originally Posted by meachamgw
is that a piggy back tuner or does it write directly to the ECM? I have a 08 Road Glide with Rineharts - thinking of air and tuner. thanks.
It's not a piggy back tuner. It flashes the stock ECM. You just save the factory map on the unit and load the custom map from the unit. It can holds up to 6 maps.
Old Jan 28, 2011 | 12:45 PM
robvg's Avatar
robvg
Call me a dumb-*** but if it's flashing or 'using' the stock ECM, doesn't that mean it's a 'piggy-back system? I'm considering this unit but have also looked at the Thundermax which is a 'stand alone' unit. (Original ECM is removed) Be gentle in your responses...I'm on a learning curve that resembles a parking lot.
Old Jan 28, 2011 | 12:54 PM
Keithhu's Avatar
Keithhu
Nope, it only means that the unit is connected to the ECM in order to upload (or flash) the new ECM parameters to the ECM (or download the existing map thats on it), once done, you disconnect it.
Old Jan 28, 2011 | 03:02 PM
Mike NY's Avatar
Mike NY
So I realize the Power Vision has alot of Bells and Whistles and doesn't require a computer to Flash. But really without an Auto-Tune feature like the T-Max which Tunes while you are actually riding , is the Power Vision that really far ahead of the HD SERT? So I don't have a little fancy screen that shows me things about my bike. I want to ride not be distracted by watching a screen... My Stock Map is long gone and will never need it but I have copies of my current Map and any other ones I have made changes to.
In any event I'll be reading and watching to see how this withstands the test of time and what bugs and issues arise if any... There are no magic devices out there...
Mike
NY
Old Jan 28, 2011 | 03:21 PM
McRider's Avatar
McRider
Mike
NY
I got it because it seemed really easy to use. The price was ok (comparable to TTS mastertune). My understanding is I can leave the unit on the bike and collect data to refine the map just like TTS . It comes with software that you load on a laptop to access all the functionality.
There is an optional autotune module with wide band sensors that will be released soon that can tune the bike while riding.
Old Jan 28, 2011 | 03:29 PM
1hellbent's Avatar
1hellbent
There is a huge thread about this system that was started last November in the Touring forum. Lots of info, lots of questions answered by both Dynojet and Fuel Motto.
https://www.hdforums.com/forum/touri...g-is-here.html
Old Jan 28, 2011 | 03:33 PM
oct1949's Avatar
oct1949
Originally Posted by rquirch
dammm... daddy likes... i have the fuelpak by V&H i dont know why i have a feeling it could run better..
Because she will run better,,, the less $$$ F/M systems such as the fuelpak only change the A/F ratio and not any timing events or A/F throughout the rpm range..
Eagle240
Jun 26, 2015 11:10 AM
Chuck Downey
Jan 16, 2015 05:48 PM
Simon Lam
Mar 22, 2013 11:30 AM
denman
May 4, 2012 08:39 AM
por2gezo
Apr 20, 2010 12:24 AM
