Softail 2007 with Twin cam 88
Old Feb 7, 2011 | 10:53 AM
hiro's Avatar
hiro
6th Gear
Default Softail 2007 with Twin cam 88
A friend of mine selling 2007 softail complete body frame and everything except the engine tranny and electrical..
i can only afford Twincam88 right now.. can i put Twincam88 engine to this softtail frame? because original softail at 2007 already using twincam 96
thanks
Old Feb 7, 2011 | 11:29 AM
stevevfd's Avatar
stevevfd
How much in total is that going to cost you? Why not look at a used, complete softail? There are lots of good deals out there. If you're going for the 88" anyway, you can find a good low milage, complete bike for not that much money. If you go that route, you need the TC88B, not the regular TC88. Even still, I don't know if it'll mount up right. Then I don't know if the 5 speed will mount up where the 6 speed was on the 2007. It sounds like a lot of work when you can get an 05 Softail Standard for under 8K if you look around.
Old Feb 7, 2011 | 11:35 AM
Dirty Fxstd's Avatar
Dirty Fxstd
i say if youre gonna basically be building a bike anyway....... build the thing from ground up the way you want it i wouldnt mess with the 07, and try and put the 88 in there
Old Feb 7, 2011 | 12:04 PM
nikonf8's Avatar
nikonf8
Default 88
i cant say for sure but i would bet it should fit no problem. basically the difference is in the stroke in the 96
Old Feb 7, 2011 | 12:05 PM
hiro's Avatar
hiro
6th Gear
1st of all i'm not in CONUS, and the complete body frame he sells to me are very2 cheap, like he giving it to me.. so what i need is the engine and electrical only... so this mean 88 engine and tranny won't fit the frame without customize... so i need to find Twin cam 96???
Old Feb 7, 2011 | 04:32 PM
08Fatty's Avatar
08Fatty
Get the bike and let it sit while you save up and put the 120R in it.
Old Feb 7, 2011 | 07:33 PM
WhiskyWarrior's Avatar
WhiskyWarrior
As long as you use 2006 or earlier softail primary and 5spd/88" I would think it should bolt in.
Old Feb 7, 2011 | 07:51 PM
bwana1's Avatar
bwana1
I think the engine to tranny bolt pattern is different between 88" and 96" so it has to be an 88 engine/tranny or a 96 engine tranny. I also think that the 88 eng/tranny fits the 07 softail frame.
Old Feb 7, 2011 | 07:58 PM
soft 02's Avatar
soft 02
+1 on saving up for the jims120.
Old Feb 7, 2011 | 08:50 PM
csc06ss's Avatar
csc06ss
I'd do a sreach for salvage motorcycles. You can probably find a wrecked late model bike with everything you need.
God bless!
Scott
