adjusting stock shocks
Old Feb 13, 2011 | 07:38 PM
FREEFALL's Avatar
FREEFALL
I know I'm gonna get some flack for this, but it works.
Jack the bike up and set her down on three blocks.
Plenty of room to get to all the crap under your bike.
HINT: Put her in gear so she don't go rolling...
Also works great when draining the transmission.
Old Feb 13, 2011 | 07:45 PM
fcsallan's Avatar
fcsallan
Not a big fan of leaving my scoot on blocks while I'm under it. That is nearly 800 lbs of hurt if it comes down.
Either way, I have done many a softail shock adjustment and never had one beat me yet. 10-20 minutes and a beer or so later, you're back on the ground and ready to go.
Old Feb 13, 2011 | 09:03 PM
oct1949's Avatar
oct1949
Ur dealer should do it for free.. had our firmed up at the 1k service..
they come set up in the middle of adjustment..
haven't touched them since then... been fine for our 2 up 90% of the time for 4yrs and 30k.
I can tell its a little stiffer for solo. but not bad at alll.
At least we don't bottom out any more unless we hit a really bad hole/bump
Old Feb 13, 2011 | 09:17 PM
JIMSFBL's Avatar
JIMSFBL
Hey bro, you said your were gonna get some slack and I could write a book on why thats not a good idea. Your a pretty cool forum member and I like reading your posts, so I'm not going to say the obvious. Be careful bro!
Old Feb 14, 2011 | 12:21 AM
FREEFALL's Avatar
FREEFALL
Thanks Jim.
I am very careful, insanely careful.
Old Feb 14, 2011 | 11:36 AM
Iron_Yeti's Avatar
Iron_Yeti
Thanks for the help guys. While I was tempted by Freefall's suggestion , I will likely head over to my local dealer. They have been very good to me so it probably won't be a big deal.
Old Feb 15, 2011 | 07:47 AM
tmitchellof PG's Avatar
tmitchellof PG
I have a 2005 SE Fat Boy which comes about an inch lower in the rear, about the same as your LO. It probably uses the same shocks as the LO and the Deluxe uses.
The dealer set mine the first time, since I couldn't break the retention nuts loose. I told them not to put any loctite on the nuts or overly tighten them.
Now I can change the setting in about 5 minutes, with the bike on the jiffy stand. I have the yellow Sears jack, but don't use it when I adjust the shocks.
I lay on the garage floor on the right side of the bike and use an open end wrench that I cut the handle down to about 4 1/2" and a $5 spanner wrench I got from the dealer. When I'm done I just tighten the retention nuts a bit past snug. They have never come loose. If anything the retention nuts tend to get tighter.
Old Feb 15, 2011 | 09:12 AM
blink1968's Avatar
blink1968
maybe you need to spring (pun intended) for a set of air shocks and mount the chuck somewhere that'd be easy to get to !??? makes sense
Old Feb 22, 2011 | 08:52 PM
spydyr's Avatar
spydyr
I usually ride 2 up & we're 400+lbs together. We've only bottomed out a few times after 12K+ miles, but that's too many for my comfort. So, I got the spanner wrench & adjusted it to about 2 threads showing. May do it more after a solo ride test. I don't want it to be so stiff I bounce off the thing when riding solo.
I thought adjusting it was SUPER easy. The spanner wrench inner section is the right size to adjust the outer nut. Just flip the wrench around so the spanner flanges are away from the shock body. Took me about 5 minutes just crawling under it on the ground.
Old Feb 22, 2011 | 09:05 PM
dandyone's Avatar
dandyone
FREEFALL, I like the lift! I do the same stuff but thats why I don't drink when I work.
Zeus55
Apr 6, 2021 11:55 AM
rpking
Oct 8, 2014 05:02 PM
EdandGrace
Aug 17, 2013 07:46 PM
Mr.Twisted
May 12, 2012 07:42 AM
StreetGlider57
Mar 26, 2011 08:34 AM
