Primary case paint
Old Feb 17, 2011 | 08:16 AM
patharley's Avatar
patharley
Default Primary case paint
I would like to know which is the process of painting used on the primary box of a harley davidson. (The flat black)
Old Feb 17, 2011 | 09:11 AM
stevevfd's Avatar
stevevfd
I think it's krinkle black powder coating.
Old Feb 17, 2011 | 01:22 PM
watchluvr4ever's Avatar
watchluvr4ever
I've always heard it's wrinkle/crinkle black powdercoat.
Old Feb 17, 2011 | 03:32 PM
Cheesecake's Avatar
Cheesecake
As other have said... powder it....
If you are dead set on DIY....
Scotchbrite it... Primer it.... then Paint it....
I would go with a heat resistant paint to be on the safe side...
CC
Old Feb 17, 2011 | 11:32 PM
bluedemon06's Avatar
bluedemon06
Its wrinkle black powdercoat. But harley makes this paint in a can called textured black I used it when I scraped the bottom of my primary and its not as wrinkled but its close. So you can try that maybe.
Old Jun 27, 2013 | 08:55 PM
rdunnill's Avatar
rdunnill
Are there any companies that specializing in powder-coating Harley powertrain parts? I have a 2008 Nightster that I'd like to convert into a Sportster Custom.
Old Jun 27, 2013 | 11:41 PM
Snowyone's Avatar
Snowyone
Default powder puff
Eastwood makes a powder coat kit that does an excellent job. The first one I bought was less that a 100$ and I just upgraded to a dual voltage one for 150. The first one works just as well. I went to the garbage bailer and found an oven for free and use my compressor plug when I need to use the oven as their both 220. It's so easy to use and they carry a powder call HD paint that's semigloss but comes out with some texture. They also have the wrinkle black and about anything or color you want. Just did a pair of junk twin cam rocker covers with the wrinkle black as a test and you have to look close to see where the chrome was peeling. They turned out so awesome I put them on my 2011 Fatboy. Now if I could ever figure out how to post pictures to these posts I'd share the results. I did my cam cover, tranny end cover, and the primary cover with the HD Black. Like the look better than the silver color Pearl came with.
Cimoehl
EVO
Apr 12, 2019 08:33 AM
harley#1
Nov 30, 2017 08:45 AM
mister g
Sep 30, 2014 01:17 PM
Farout68
Jan 14, 2013 05:49 PM
PG13125
Mar 7, 2010 01:54 PM
