Passing Light and High Beam wiring. Help
Old Feb 24, 2011 | 03:08 PM
jdunn01's Avatar
jdunn01
Default Passing Light and High Beam wiring. Help
Ok call me stupid but I have a 08 Heritage and want to do the mod to have my passing lights stay on with my High Beams.
I have the following schematic
Can someone please tell me exactly where you spliced into the Acc Wiring? Did you you does this under the tank console that the switch is mounted in?
Help
Attached Thumbnails Passing Light and High Beam wiring. Help-passing-lights.jpg
Old Feb 24, 2011 | 04:13 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
The acc wire plug is on the left side near the front of the tank under the tank. It is orange and white on my bike not orange and red, but my bike is older (2002)
Drew
Old Feb 24, 2011 | 04:57 PM
jdunn01's Avatar
jdunn01
Did you have to remove the tank?
Old Feb 24, 2011 | 05:06 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
No. Take the front and rear bolts out of the tank, take off the fuel line and just slide it back.
Drew
Old Feb 24, 2011 | 05:12 PM
Jeff W's Avatar
Jeff W
hey, dont have a Heritage, but on my dyna, pull the rubber grommet out of the neck where the headlight wires route, 3 wires from headlight, but where it plugs in to main harness there is a 4th wire (not used) that is orange with a white stripe that stays on no matter if you run high or low beam, it goes hot when the key is on.
wire colors on main harness was black, white, yellow, orange/w white stripe.
Old Feb 24, 2011 | 07:52 PM
jdunn01's Avatar
jdunn01
Ok so if I connect the yellow from the passing light switch to the orange acc wire I can still turn them off with the passing light switch right?
Old Feb 24, 2011 | 07:58 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Yes, that is what you want to do. I used a quick splice.
Drew
Old Feb 24, 2011 | 08:09 PM
jdunn01's Avatar
jdunn01
Kewl thanks for the answers folks. I will let you know how it works.
Berick
Mar 31, 2015 09:56 AM
HarleyJeepMan
Mar 11, 2015 01:20 PM
Dutch101st
Aug 17, 2014 08:51 AM
cmosentine
Mar 31, 2012 03:28 PM
rde
Dec 2, 2009 11:11 AM
