Belt tension
Old Mar 8, 2011 | 08:59 PM
bigben46's Avatar
bigben46
Stage IV
Default Belt tension
I have a 1993 fxstc that came with a lowering kit. The bike is too low for me so I want to raise it up a bit. Will this change the belt tension? Thanks bigben
Old Mar 9, 2011 | 06:53 AM
handyhoward's Avatar
handyhoward
Yep... it will loosen it.
Old Mar 10, 2011 | 06:03 PM
bigben46's Avatar
bigben46
Stage IV
Thanks Handy. Maybe you can help me with something else. Which would you turn the adjusters on the kit CW or CCW to raise it? Thanks again for your help. BIGBEN
Old Mar 11, 2011 | 06:47 AM
handyhoward
You want to shorten the shafts on the shocks... It's been a while, but I think you loosen the lock nuts ccw and turn the far forward nut cw... this should pull the shaft forward. Remember that each 1/4 inch on the shock shaft is about an inch movement up or down on the rear end.
MNrider
Apr 27, 2021 06:31 PM
tom_sprecher
Oct 23, 2012 03:14 PM
tom_sprecher
Oct 22, 2012 06:46 PM
Lachaine
Apr 12, 2012 05:01 PM
jsbridgew
Apr 27, 2008 09:09 AM
