Pc-v troubles...need input
Old Mar 10, 2011 | 11:35 AM
WATERHAWG08's Avatar
WATERHAWG08
Unhappy Pc-v troubles...need input
I have the PC-V Retro fit from FuelMoto on my 2008 NT, here's my problems:
When I first installed it, my right turn signal and sercurity lights would flash intermitently, I call Keith at FuelMoto and he walked me thru a firmware update. It didn't fix it and now has a little bit of vibration, that wasn't there before, when I'm on the gas. Called FuelMoto and we did a new firmware update, now ALL the lights on the bike, the dash and the fuel pump come off and on...looks like a christmas tree...called FuelMoto, they never heard of such. Called Dynojet direct, they never heard of such. So removed PC-V and plugged my ECM back in direct, still have all the lights flashing and fuel pump coming on and off. Calling Dynojet back tonight, to walk me thru some new procedure? Any input needed, I'll keep posted.
Old Mar 10, 2011 | 11:53 AM
Mr.Softy's Avatar
Mr.Softy
That's kind of scary. Did you check all your connections maybe one came a bit loose?
Old Mar 10, 2011 | 11:58 AM
WATERHAWG08
Yeah, everything seemed ok, I just hope my call to Dynojet tonight, resolves this. Hopefully I didn't get a bad PC and it fryed my ECM
Old Mar 10, 2011 | 01:48 PM
Gman in NC's Avatar
Gman in NC
If that don't do it I think I'd try removing the security module and put the PC-V back in. At least you'd be eliminating that part of it.
Old Mar 10, 2011 | 02:38 PM
CountryD's Avatar
CountryD
Hey for what its worth. Buddy of mine had the same problem, he went through and checked all the connections and found nothing wrong. In the end his ECM went out. He called everybody also, dealer, Jamie, everybody. SO I hope your not in the same boat. But on his it made a buzzing sound when he turned it on, then all the lights would go crazy. Hope you dont have a bad ECM
Old Mar 10, 2011 | 03:32 PM
WATERHAWG08
C D, sounds just about like what is going on with mine, man I hope it didn't fry me! Dynojet told me to check every pin with a flashlite, might have one bent over or not in the socket good, I hope it's something like that.
Old Mar 10, 2011 | 04:03 PM
Ash16's Avatar
Ash16
I hate to hear that your having problems Waterhawg. I've had mine in for over a year with no issues.
Old Mar 10, 2011 | 04:33 PM
WATERHAWG08
Man I can't wait to get home from work, to start going over everything, I just hope it's something simple and not my ECM.
GPHDXLC
Jul 3, 2011 07:41 PM
BigD64
May 31, 2011 02:46 PM
dohadex
Feb 21, 2011 06:46 AM
Puttnutt24
Jun 13, 2010 02:25 PM
pled55
Dec 9, 2008 02:38 PM
