Tranny Drain Plug Stripped
Old Apr 7, 2011 | 08:22 AM
CYCLE's Avatar
CYCLE
Bring it to the dealer so you don't mess it up any more then it has to me and you wont have any aggravation doing it and its done right with a piece of mind!
Old Apr 7, 2011 | 08:42 AM
handyhoward's Avatar
handyhoward
Originally Posted by cycle
bring it to the dealer so you don't mess it up any more then it has to me and you wont have any aggravation doing it and its done right with a piece of mind!
not always!!!
Old Apr 7, 2011 | 11:42 AM
NorCal Dog's Avatar
NorCal Dog
Originally Posted by LDB187
Torquing didn't have anything to do with it. It was trying to find the hole up between the two shocks. Just got crossed threaded. I like the idea of just buying a new bike. As for the helicoil, is there a way to put one of those in without removing the tranny?
the cross threading part wasn't mentioned in the OP, so i figured it was over torqued
good luck with the repairs bro
Old Apr 7, 2011 | 11:56 AM
97FXSTSB's Avatar
97FXSTSB
Using a long 1/4 Allen socket (long Allen, not a long extension) rather than the usual 5/8 socket makes it easier to squeeze between the shocks and reduce the chance of crossthreading
Old Apr 7, 2011 | 12:43 PM
lionsqrne's Avatar
lionsqrne
Exactly what I use now.
Old Apr 7, 2011 | 02:27 PM
LDB187's Avatar
LDB187
Thanks for the tricks and tips. I really never give it any thought except for that one time per yr when I change it but I'm going to have the dealer do the cam tensioner conversion so might as well have them repair that also.
Old Apr 7, 2011 | 04:35 PM
Yosemite's Avatar
Yosemite
Same thing happened to me LD on about my third time changing it. Talked to some folks including techs at two HD dealerships and they all said the same thing. That being (a) it is not uncommon, especially cross-threading, and (b) they all used the following procedure to fix it.
Go to the auto parts stores and look for an oversize self tapping plug with an o-ring sealing center drain bolt that comes out. I found them at Auto Zone and Pep Boys both. I bought several sizes after eye-balling the original plug against them (stated size seems to be variable) and after trying several, found the one that fit the best.
I don't have one of the gold scissor jacks folks use on bike lifts so I took the wheels off my regular floor lift (the one you can pull around like a floor jack), slid it under my bike while on the big lift and jacked it up about 12-16", locked down the jack and tied down the bike. This gave me lots of room to get up under it and screw the thing in straight this time.
I threaded the tapping base in slowly, backing out several times after about 1.5 to 2 threads were cut, cleaned it off, cleaned the threads off, etc. until I'd tapped it all the way to a seated point. Then I poured kerosene through the filler hole to wash it out, did it a second time with a 1/4 quart of oil mixed with the kerosene 50-50, and then blew it out with high pressure air from the top. Finally just stuck my finger in and worked it around to be sure I could feel no other thread shards.
After that, it was a matter of screwing the whole thing in and torquing to spec, and filling with trans fluid. No problems in 10k miles and no leaks.
Hope this helps.
Old Apr 8, 2011 | 06:14 AM
LDB187's Avatar
LDB187
WOW, that's a pretty awesome technique there. Thanks a bunch YO....
Old Apr 9, 2011 | 09:07 PM
cpiad's Avatar
cpiad
Account Closed
Originally Posted by lionsqrne
I stripped mine on my 07 about the 3rd oil change. Was in a hurry as I was going riding and used a socket to quickly.
Put a helicoil in it. Been fine ever since.
Helicoil + one.
Old Apr 9, 2011 | 09:10 PM
cpiad's Avatar
cpiad
Account Closed
Dealer doing something right? You must live in a parallel universe. Here the dealerships will strip the hole and lie about it. A bunch of 18 yr old kids and some lazy knumb skulls.
John7253
Shovelhead
Jul 12, 2016 08:40 AM
cajun1957a
Shovelhead
Aug 24, 2014 01:58 PM
UT-rckr
Dec 17, 2012 10:29 PM
met.75
Apr 29, 2009 05:09 AM
95ci springer
Sep 22, 2008 12:24 PM
