left turn signals not working
Old Apr 8, 2011 | 06:39 PM
camadon1971's Avatar
camadon1971
Default left turn signals not working
I recently installed new rear tuirn signals on my 1997 fatboy. When i press the left turn button at idle the turn signals flash. Anything above idle and they just stay bright. I am guessing I wired it backwards. Sound right?
Old Apr 8, 2011 | 08:09 PM
Gman in NC's Avatar
Gman in NC
Hard to say. But, only you know exactly what you did and that's the first place I'd look. You're using good logic here.
Old Apr 9, 2011 | 07:12 AM
FroggyFatBoy's Avatar
FroggyFatBoy
i would think if you wired them backwards they wouldn't work at all.
Old Apr 9, 2011 | 08:42 AM
RANGER73's Avatar
RANGER73
Were the old lights 2 wire and new lights 3 wire?
Old Oct 30, 2016 | 03:01 PM
dr.dentfix's Avatar
dr.dentfix
6th Gear
Default same issue
new front and rear turnsignals went from 3 wire to 2 wire they all work at idle but the left one stays on not blinking when engaged at highway speed
Old Oct 30, 2016 | 03:08 PM
sevebou63's Avatar
sevebou63
One of those wires out of the three is a daytime running light . You probably hooked up the daytime running wire instead of the blinker wire. Check your wiring again.
Old Oct 30, 2016 | 03:13 PM
dr.dentfix's Avatar
dr.dentfix
6th Gear
but they work at idle only the left does not work while crusing
Old Oct 30, 2016 | 03:25 PM
sevebou63's Avatar
sevebou63
One of three things......bad light....wired wrong or a short.... I would grab a multimeter and start testing.
Only other question I would have is....Are your new lights LED's? If so you may have to install resistors.
Without being right there to look....hard to say.
Old Oct 30, 2016 | 03:38 PM
dr.dentfix's Avatar
dr.dentfix
6th Gear
yes the fronts are led the rears are bulbs checked wires they are all wired the same and no shorts
strange that they work at idle but not while crising..as you slow down it will work and its onlt the left side
Old Nov 1, 2016 | 08:04 AM
sevebou63's Avatar
sevebou63
I would assume that when your rpms are rising the voltage is also increasing in the wire enough to cause the leds to malfunction. Sounds like you will have to install resistors for the leds.
roughedges74
May 20, 2014 06:48 AM
tyrantjon
Apr 1, 2014 02:38 PM
Matt K
Sep 24, 2013 05:55 PM
springer06
Apr 10, 2008 04:19 PM
ottodoggy
Apr 20, 2007 02:43 AM
