help with handlebar install
Old Apr 8, 2011 | 06:47 PM
trailblazer1966's Avatar
trailblazer1966
1st Gear
Default help with handlebar install
I have an 09 train and will be installing apes.Was wondering if anyone has just disconnected the fuel line but not the cross over and just slide the tank back to get to the wiring plug.If so,did you have to take off console or disconnect fuel pump.Thanks for any help.
Old Apr 8, 2011 | 09:38 PM
MCSarge's Avatar
MCSarge
The plug is right behind the plastic cover at the front of the tank. I was able to remove one side and the headlight plug but had to disconnect the crossover and raise the tank to get the other two. If you have small hands you might be able to do it.
You will have to take the console off but it's held on by one bolt. The vent tube is at the front of the tank under the console.
Old Apr 8, 2011 | 09:44 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Take off the console, unplug the fuel line and slide it back. I can do it that no without issue. It saves a lot of time.
Drew
Old Apr 8, 2011 | 09:59 PM
wlbowers's Avatar
wlbowers
Oh Yea. Just be careful.
Old Apr 8, 2011 | 10:05 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
I should have clarified. Lift slightly and slide back with your hands. You can see how far it will slide by checking the crossover.
Drew
trailblazer1966
Apr 8, 2011 09:15 PM
Cpitch
Mar 28, 2011 12:25 PM
SpyderTB
Exhaust System Topics
Oct 27, 2009 09:18 AM
rome304
Oct 31, 2007 07:59 PM
Johneb48
Oct 19, 2005 09:40 AM
