voltage regulator/battery
Old Apr 10, 2011 | 02:07 AM
ginadavies25@yahoo.com's Avatar
Stage II
Default voltage regulator/battery
i need some help. i think i have to replace my voltage reg. i have replaced my battery and the bike seems to not want to keep a charge... on a trickle charger the battery does not last longer then about 2 hrs at a time without having to get her home and recharge.. my husband and i have had to push start 2-3 times at any given outing.. then she has to be recharged.. anyone, please help
Old Apr 10, 2011 | 06:34 AM
08Fatty's Avatar
08Fatty
Look in the service manual and there is a test you can do on the stator to see if it is working. Sounds more like that to me. All you need is a volt meter. I don't remember what the voltage is supposed to be right now. If you don't have a service manual, maybe someone will explain the test or I can lookit up later and explain it. Good luck.
Old Apr 10, 2011 | 10:28 PM
Stage II
ok thanks... i appreciate the help, i'll check the manual...
Old Apr 11, 2011 | 06:29 AM
Mike T's Avatar
Mike T
Make sure the plug connections are tight in the voltage regulator.
Old Apr 11, 2011 | 07:06 AM
handyhoward's Avatar
handyhoward
Sounds like a stator problem... not recharging the battery when the bike is running. Everything is running off the battery... lights, etc.
Old Apr 11, 2011 | 07:40 AM
Blk and Chrome's Avatar
Blk and Chrome
You need to check the voltage should be 14.5 give or take a couple tenths of a volt. If not unplug the stator which comes out of the ft of the inner primary housing put the volt meter across the two terminals and when you rev it up a little you should see voltage increase like from 10-20 to past 40 and above depends on how much rpm you have. if there is no voltage or little change then you need a ststor if there is the voltage regulater is bad. when you test at the battery it is in DC the stator will be read in AC
TSD
May 2, 2014 06:15 AM
kentcitydj
Jul 15, 2012 02:27 PM
mar10nz
Aug 28, 2008 11:19 PM
JR_rivard
Jul 17, 2008 12:44 AM
diverider
May 14, 2008 10:07 AM
