Front axle slider bolt heads rounded, now what?!?
Old Apr 30, 2011 | 12:49 PM
tlb's Avatar
tlb
Have you considered just hitting them a hammer and flatting them out a little bit and try the allen again? You could also try cutting a slot in the head and using a large screw driver.
Old Apr 30, 2011 | 12:56 PM
IceColdDeluxe's Avatar
IceColdDeluxe
No, I hadn't considered that. However, they are in there so tight that I don't think my allen wrench could muster the job. I really don't want to cut it off and throw it in a drill to not have it work. The dremmel should make quick work of the heads and then I'll just need two new bolts. Small price to pay for not doing the slider replacement myself last year.
On the bright side, I really felt like the local dealership was interested in helping me this morning. I didn't live here last summer when I had the work done, but they were at least very considerate of my situation and offered to help in any way they could.
Old Apr 30, 2011 | 01:09 PM
tlb's Avatar
tlb
I hope it all works out for you. If you use a drill bit the same diameter of the bolt you could just drill the head off. A drill would be a cleaner way of cutting the head off, than a dremmel.
I am out of here, the wife and I are going to take a ride this afternoon.
Old Apr 30, 2011 | 01:19 PM
IceColdDeluxe
Wheel is off. The cordless dremmel worked well, although I wish it went up to 35k rpm instead of just 30k. Off to the shop to buy new bolts and clamp once I get the two bolts completely removed. Then, it's on to the actual install...
P51Driver
2018+ Softail Models
11
Jun 28, 2019 03:01 AM
BuckeyeUltra
May 6, 2014 08:04 AM
rlchristensenmd
Apr 8, 2011 08:07 PM
rdondes
Oct 4, 2010 07:40 PM
2007fxdc
May 4, 2010 07:59 PM
