How do I get a little more slack on the clutch lever? (mid cable adjustment?)
Old May 10, 2011 | 09:21 AM
Nicky Pass's Avatar
Nicky Pass
Default How do I get a little more slack on the clutch lever? (mid cable adjustment?)
After getting my bike back from the ape install, I noticed that the clutch lever is pretty tight.....as in there is almost no lever play. I'm no expert, but if I recall correctly, there should be play.....correct? It squeezes easy an it starts to grab about 1-1.5" off of the grip. If all this seems normal, just let me know....I just remember thinking I have to push the lever forward to get it to extend all of the way, now it does it on its own. I have magnum cables, can I adjust the mid-cable adjuster....if so, how do you do it?
Old May 10, 2011 | 09:43 AM
DaddyKnuck's Avatar
DaddyKnuck
Loosen the lock nut, turn the adjuster in until you have about 1/8" between the perch and the lever (should swing 3/8" or more at the lever ball), tighten lock nut.
Old May 10, 2011 | 10:33 AM
Keithhu's Avatar
Keithhu
Jeez, nobody should be shocked that they mangled your chrome. They can't adjust a clutch cable properly?
Old May 10, 2011 | 10:35 AM
Nicky Pass's Avatar
Nicky Pass
I'm not at home, all I remember is there is threads showing on the adjuster....there is a lock nut on it? Pardon my stupidity, I just want to know I'm doing it correctly! Is there any pics or anything?
Thanks!
Old May 10, 2011 | 11:56 AM
Kowan's Avatar
Kowan
Yes there is a lock nut.
http://www.youtube.com/watch?v=iiC5d2gBoKU
Old May 10, 2011 | 12:27 PM
Jeff W's Avatar
Jeff W
Yes, the cables have a lock nut, magnums lock nuts and adjusters don't have a hex head though, they will be round with two flat sides for wrenches.
Old May 10, 2011 | 03:17 PM
Nicky Pass's Avatar
Nicky Pass
Which way is which...what way do I turn it to get a little more slack?
Thanks guys!
Old May 10, 2011 | 03:24 PM
Northside's Avatar
Northside
You'll want to turn it up toward the lock nut, effectively shortening the housing in relation to the cable. Try a couple of turns and check your freeplay. If you turn it the wrong way you will lose all feeplay, so then go the other way. Pull the clutch in a couple of times to make sure the ***** are seated in the ramps in the end cover.
Old May 10, 2011 | 08:49 PM
DaddyKnuck's Avatar
DaddyKnuck
Thanks guys!
The adjuster should be underneath an accordian rubber cover near the left down tube. The lock nut should be 9/16" and both ends of the cable are 1/2". Using a pair of wrenches crack the lock nut loose (righty-tighty/lefty-loosey). As previously mentioned turn the lock nut a few turns to allow the female end of the adjust some room to move. Since you don't have enough free play, turn the male end clockwise a thread or two and check your free play. When you've got about an 1/8" between the lever and perch you're probably good. I tend to get the amont of free play I want plus about 1/16 of a turn extra to allow for a little movement when tightening the lock nut. With a new cable this will be a piece of cake.
street_glider
Jun 1, 2010 10:49 AM
tru510
Feb 17, 2009 09:18 PM
FX4 Level II
Feb 4, 2009 08:19 PM
jaycross
Apr 13, 2008 01:52 PM
so165
Apr 9, 2007 09:37 PM
