New cams
Old May 14, 2011 | 04:44 PM
roadkingharry's Avatar
roadkingharry
Originally Posted by av8or
I have always wondered about the weight of the adjustable push rods. I know that they must be heavier that the stockers, but by how much, and does it hurt performance or longevity any way.
The weight difference is probably negligible and doesn't effect performance. There's an article in last and this month's American Iron about Hillside's (site sponsor) 98" build and they put in S&S adjustables even though the entire top end was apart. Adjustables are the "perfect fit" although I didn't use them in mine.
Old May 14, 2011 | 05:57 PM
chamokie's Avatar
chamokie
Just did mine, not hard at all. Get the factory manual, read and read some more until you can do the whole job in your head. Then you will have all the confidence you will need. Once I understood what I had to do, I used the manual for tq specs. You will need a special puller to remove the cam bearings, and I suggest you use the up graded cam bearings. If you reuse the OEM push rods you have to remove the tank, I cut mine off and replace with S/E adj push rods, I my little brain a lot easier. PM me if you need any info will be glad to help.
internet troll
Jun 3, 2019 01:47 AM
lhgdale
Jun 26, 2013 10:31 PM
06fxsti
Aug 24, 2012 08:50 AM
Green Machine 04
Exhaust System Topics
Aug 31, 2010 04:05 PM
AdrianVall
Jan 20, 2009 06:53 PM
