Getting a Train I am 5'10 32 inseam.I can't decide between the Carlini clean sweep t-bars which give 7" inch pullback and 7" height.Where the Wild One t-bars WO 500's give 6"height and 10.5" pullback and finally the H-D Streetslammer bars all it says is 7"rise?? Out of the 3 what would let me sit BACK more and be more comfortable ????thx pros and cons
I'm 5'8 with a 33 inseam and at first I installed duece risers with the stock drag bars on my '06 train. That helped some. I then purchased the WO501 bars and the street slammers to try out. The 501's were my choice, being a little taller and a bit more pullback than the slammers. I still have the duece risers if you or someone else is interested.
I have also installed 3" extended front controls by Ness - helped a bunch.
Lucky Bob:
I'm just about Max Evo's size and riding an '07 Train...
I'm doing surprisingly well with the stock set up but I was wondering how the Deuce risers would work if I want to try something different.Did you use the stock Deuce risers ?
Were all the original cables and lines long enough to do the modification or did you need longer ones ?
How much of a change was it,about how far rearward did it move the drag bars ?
