Novelty Helmets
Old Dec 3, 2012 | 12:24 PM
  #101
KumaRide's Avatar
KumaRide
Just checked, my Outlaw ultra low profile carbon profile DOT has the "DOT FMVSS No. 218 Certified" on the inside label. I love that helmet even more now! lol
http://www.leatherup.com/p/Outlaw-AX...et/381941.html
Old Dec 3, 2012 | 01:50 PM
  #102
GinsengSullivan's Avatar
GinsengSullivan
Originally Posted by fat_tony
With a non DOT helmet you don't get to enjoy the wind in your hair but don't get the head protection of a DOT, SNELL OR ECE lid either. You get the disadvantages of wearing a helmet and the disadvantages of not wearing one but none of the benefits of either.
Seriously, I don't understand, why would someone want to buy a helmet knowing it does not meet the very minimal DOT standards for head protection? Seriously I am hoping someone can provide a truthful answer to this question.
Like I've stated before;
For what it's worth as far as my opinion on DOT v non DOT. I ride in a "made in the USA" Skull Crush helmet made of KEVLAR/CARBON FIBER (instead of the plastic/fiberglass/polycarbonite that DOT helmets are made of) with a moisture resistant memory foam interior, good at dissipating energy instead of transferring it (instead of the styrofoam / terrycloth interior of most DOT helmets).
Now why is it not DOT? simply because of a standardized thickness requirement (needed by the cheap styrofoam interiors used by most) regardless of construction. The size, specs, and materials are completely different.
For a strap connection, you can choose a Military Spec Quick Disconnect. As with every component of this helmet even the connectors are made of high strength and durability.
I choose to spend my money on a product that is individualy made in the USA to exacting spec with QUALITY materials. Can you say the same about your plastic, assembly line, foreign made DOT? Just something to consider before questioning anothers decision on what they want to wear.
Old Dec 3, 2012 | 02:02 PM
  #103
Liberator's Avatar
Liberator
Damn! Really? I guess I can see that in that the bottom view looks like it's got a decent amount of foam in there.
Old Dec 3, 2012 | 02:22 PM
  #104
Motown Strag's Avatar
Motown Strag
Safety ***** make me laugh because by their own statistics it shows that you cant safely ride a motorcycle on the same road with cars and yet they do...and then feel like they need to lecture others over a little Styrofoam.
must be getting boring around here lately
For the record DOT does not approve helmets. they only mandate the requirements and let manufacturers self certify. DOT does limited validation audits from units in the market place and if a helmet doesn't pass they make the mfg. do a recall. So basically what you are buying the manufacturer is only claiming that it passes based on third part results from a 17025 accredited laboratory. Thats a one time test...not continual in-process testing batch by batch throughout the year. It only validates design, not process and process variation.
The foam is thick so that the helmet passes the penetration test. The penetrator on the impactor always goes through the shell.
That foam will not attenuate a significant amount of energy to keep the brain from decelerating against the inside of the skull (which will cause the brain damage) It just keeps your skull from splitting open.
At the right speed, right angle and a reasonable amount of energy the helmet will save your life but one half an inch thinner most likely would as well.
Old Dec 3, 2012 | 02:28 PM
  #105
Benway's Avatar
Benway
Now why is it not DOT? simply because of a standardized thickness requirement (needed by the cheap styrofoam inteirors used by most) regardless of construction. The size, specs, and materials are completely different.
Can't argue with that.
Speaking for myself (mr. Cheapskate), I'm borderline not wearing a helmet at all, so I'm going for a helmet like the low profile Outlaw because it's the smallest DOT on the market so I don't look like a goof ball wearing it and the cops won't bug me. Beats a novelty helmet for protection (and legality) and sure as hell beats nothing at all.
Doesn't hurt that it's very affordable.
Old Dec 3, 2012 | 02:30 PM
  #106
jadlh's Avatar
jadlh
Wow, Bronson on your avatar!
Old Dec 3, 2012 | 04:50 PM
  #107
Midgard's Avatar
Midgard
Seriously, I don't understand why you spend all your time patrolling helmet threads and lecturing people about non DOT lids - Seriously dude you pop up on every frikin helmet thread I have ever looked at.
Seriously, if you spent the same time you do being annoying on these non DOT helmet threads and use that time to design a DOT helmet that is half as thin as the current DOT ones - you would be contributing something useful
Everyone here that wears a non DOT lid fully understands what they are doing and don't need you "parenting and patrolling" - Seriously
Old Dec 3, 2012 | 05:21 PM
  #108
Wide_Open's Avatar
Wide_Open
My Skull Crush just came the other day. I'm liking it, it's a well made product.
Old Dec 3, 2012 | 07:05 PM
  #109
PPBART's Avatar
PPBART
Originally Posted by Malingerer
These helmet threads never seem to go well or end well.
Nor do they ever seem to have any new info or real conclusions(!)
Old Dec 3, 2012 | 07:59 PM
  #110
Quadancer's Avatar
Quadancer
How's the fit? Any bubblehead? Mushroom brain?
For the record, the Outlaw has to be ordered 2 sizes too small for you, so the original $69 price was offset by the $13 reship when my first was waaaay too small. End result worth it all tho, after a bit of reshaping.
Here and there I see one of those BIG dudes wearing the beanies, usually tipping the scales at around 270 or so...and I think with their mass and joggling cheek wattles, triple chins and so forth ... they look totally stupid with it.
There's a point where you just don't NEED a yamikah!
