Where to anchor a battery tender pigtail?
I'm sure the best place is staring me right in the face, but as of now, I am blind to it. Any suggestions would be appreciated. Thanks.
Anchor it to the coil wires, and make sure that you leave enough cable so it can fold UP (SnapClip end), and be hidden by the coil and cover....
I have seen it happen inumerabe times in cars and trucks where the wires are touching or just too close to some part of the block, body or other wires. Start it up at night with the hood open and its like a blue light show with high voltage arc's jumping all over the place.
I looked on my Custom and found a couple of places that might suit your needs.
This first one is behind the oil tank, there already is a harness running through there that you can strap it too.
This second one is in the front of the oil tank. Behind the coil there is a wire running down the fron of the tank that you can strap it too..
I'll be getting a tender in the next week or two and I'm thinking that the first one looks like the best bet.
BTW when you had the seat off and the battery exposed did you notice if the terminals looked a little close to the tank sides?
Somebody had a problem with their battery shorting out to the tank and cooking the braided oil lines and starting a fire. Might not be a bad idea to make sure it has something non-conductive between the terminals and any metalic parts of the tank its sitting in.
Not SPARK PLUG WIRES.......
Guess what???? You gave pics to where to attach it to... and guess what those wires are (in the 2d pic)?????
The coil lead....
And when you zip tie it, you ensure that you have some length, so the end isn't dangling down and hidden.....
You tuck it behind the coil......
I have no such excuse, I don't particularly like beer. But i do like Vodka!!! [sm=icon_cheers.gif]
COIL WIRES!!!!!
The coil lead....
