HELP! Rear O2 sensor
Old Jun 1, 2011 | 01:44 PM
AjAnd3rson's Avatar
AjAnd3rson
Exclamation HELP! Rear O2 sensor
I don' know how the hell it got caught but while I was pulling my stock exhaust off the rear O2 sensor came with the exhaust.
Now I cant find where the hell it pulled from.
Here is what it looks like.
I have a 2011 Fatboy lo.
Any insight?
Any help would be much appreciated.
Old Jun 1, 2011 | 02:35 PM
01fxst's Avatar
01fxst
Any insight?
The plug that you pulled this out of is located underneath the oil tank. At least it has been on the bikes I've worked on. It's hard to see and harder to reach.
The last bikes I worked on were an 08 FXSTC and an 09 rocker. You may be able to see the clip that holds it to the bottom of the oil tank if you pull the battery. Worked for me.
Old Jun 1, 2011 | 04:46 PM
AjAnd3rson's Avatar
AjAnd3rson
That got it!
Thanks so much!!!!
Old Jun 1, 2011 | 04:47 PM
ghostrider69's Avatar
ghostrider69
One of the problems is that people are trying to unscrew their O2 sensor with it still plugged in. That is a big NONO. You can and will damage the wires going into it. The plug is under the oil tank. It's not too hard to get to from the right side of the bike. What might also work good is to remove the battery and tray from the oil tank and the plug should then be right there looking at you.
Old Jun 1, 2011 | 05:12 PM
ssrgeoff's Avatar
ssrgeoff
Just dealt with this same issue this weekend.. the wires actually pulled out from the plug. As mentioned mine was located under the oil tank, I found it was easiest to pull the battery out and fix.
Old Jun 2, 2011 | 12:58 PM
01fxst's Avatar
01fxst
Default Yaaayyyy!!!
I helped somebody.
It's usually me needing help.
Old Jun 2, 2011 | 01:15 PM
AjAnd3rson's Avatar
AjAnd3rson
I helped somebody.
Ha!
It's much appreciated!
Just remember....There will always be someone on here newer and dumber.....(This guy)
Old Jun 3, 2011 | 07:19 AM
cwsharp's Avatar
cwsharp
Hey ghosty...
Where's the pause button on your avatar?
C#
Old Jun 3, 2011 | 08:40 AM
ghostrider69
Sorry no pause button.
Lo 1
Apr 9, 2017 06:43 AM
jeff6898
Aug 27, 2014 07:40 PM
bsibold
Jun 21, 2013 04:12 PM
norcal
Mar 23, 2012 01:20 AM
ssrgeoff
May 28, 2011 10:33 AM
