cutting down windsheild
Old Oct 31, 2006 | 10:33 AM
randyj's Avatar
randyj
Default cutting down windsheild
I have a HD detachable king size windsheild on my Fatboy and would like to cut it down a few inches. Any recomendations on what type of cutting tool to use?
Old Oct 31, 2006 | 10:46 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Default RE: cutting down windsheild
I would call around to some of the local glass and mirror shops to see if they would do it for you. Every time I tried to cut that stuff it turns into a minor, or maybe not so minor disaster. If your just interested in a straight line cut its fairly simple, score it and break it. Then sand the edge down. But for curves and complex cuts you need to really have a lot of practice and the right tools or it will come out like crap, or just wreck it.
You could also get a replacement piece of Lexan or Polycarbonate that's shorter.
Old Oct 31, 2006 | 01:50 PM
billnourse's Avatar
billnourse
Here's all the info you will need. It's really not that hard to do.
https://www.hdforums.com/m_312103/tm.htm
Hope this helps.
Regards,
Bill
Old Oct 31, 2006 | 09:07 PM
Kid N8's Avatar
Kid N8
This is the method that I used, but I used my Dremel tool to do the cutting. It took a little time to get the right amount of pressure on the plexi regulated to allow the blade to move through it without too much melting. But the Dremel allowed me to be worry less because that tool is so small it can't do a whole lot of damage too quick. By the way I trimmed off 3.5 inches from the top because I like to look over it instead of through the thing. I love the height now, and hope that its still good after I either have my seat shaved this winter, or check out the Mustang.
Old Oct 31, 2006 | 09:12 PM
KeithB's Avatar
KeithB
Big Kahuna HDF Member
you tape it then mark the tape. then use a fine tooth jig saw blade
Old Oct 31, 2006 | 09:13 PM
KeithB's Avatar
KeithB
Edit: Opps server burp, sorry about double post
Old Jan 3, 2007 | 06:01 PM
randyj's Avatar
randyj
Fianally got up the nerve to cut my windsheild down and it turned out great, looks like a factory job. Taped it used a jig saw filed down the rough edges and sanded. Didn't have the ***** to usea belt sander billnourse post!
Old Jan 4, 2007 | 03:53 PM
Hardley riding's Avatar
Hardley riding
Ditto, Used the fine tooth jigsaw and then used 3M sanding pad, gave the edge a nice finished look. No issue at all, took about 30 min. including set up, tape, cut, sand and cleanup.
Good Luck.
Old Jan 5, 2007 | 04:08 AM
Bluerose
Guest
Posts: n/a
Hubby did mine ... said it was easy...looks great to me
Slvr764
Sep 25, 2018 08:26 AM
Shawrco
Exhaust System Topics
Jan 23, 2013 04:01 PM
xwhyz1959
Feb 12, 2011 08:04 PM
DR. V-TWIN
Sep 15, 2010 03:26 PM
mrbuck
Mar 20, 2008 05:25 PM
