Hello,
I wish I could describe it better, but when I ride fairly slow, 1st or 2nd gear, I can hear a weird "shiiiiiish" sound from somewhere towards the front half of the bike, I think. It's loud enough to hear over the engine at low speeds and RPM and I am not sure if it is a sound from the gas tank, like the fuel pump, or the air cleaner or maybe the front wheel.
Since I am new to HD's, I don't know what to expect as normal. I have a 2011 Fatboy Lo (with the ABS/Security system, if that matters).
I hear a sound from the front of my bike to like you describe. Also at lower speed you can hear the valve train pretty good. I would say it is normal. Every thing seems to be in tip top shape and the bike runs good. Good to see you up and running Wabbit. Glad all worked out for you. Enjoy the ride Bro.
I was able to get home Friday for 24 hours. took the wife out out for about a 5 hour ride. Had a great time. I see your from Main, My wife is from up north a small town called Passadumkeag.
It could also be your primary and its normal, In 2007 they went to an auto-tensioner system (thus no more door to adjust the primary chain) which can be a bit noisy.
Does the sound go away if you lightly squeeze the front brake? If so could be slightly warped brake rotor.
Originally Posted by Wabbit
Hello,
I think he is describing a sort of buzzing sound like I get in 1st and 2nd gear it is up front some where I think it is just the tins around the upper fork vibrating.
yup...
does the sound go away if you hold the clutch in?
I hear the same thing on mine. I'm pretty sure it is the valve train. Talked with mechanic at dealer when I first heard this, I let them ride it and said that's what it is.
