Front Brake?
Old Jul 5, 2011 | 08:30 AM
wiktor's Avatar
wiktor
Default Front Brake?
Hi Guys,
Was riding my 2011 fatboy and noticed the front brake master cylinder was leaking. When I got home I wiped it off, backed out the screws and tightened the cap to 15 inch pounds, what the spec is in the service manual. This slowed it way down to a very slow seeping. Would you try to get rid of the leak altogether or just leave it as is? Also, my front brake lever engages right away, is there any way to get a little "play" in it?
Thanks!!
Old Jul 5, 2011 | 08:50 AM
Fatboy Brian's Avatar
Fatboy Brian
Since it has warranty I would take it to the dealer and make them fix it. It needs a new rubber seal. I don't think the brake is adjustable.
Old Jul 5, 2011 | 08:53 AM
Fatbob usmc EOD's Avatar
Fatbob usmc EOD
I'm thinking that this is covered under warranty so I would take it by the dealer and have them fix it. If they won't or you don't want to take it to the dealer then you probably need a new gasket to get the leak to stop completely. I wouldn't let it just leak because you could one day squeeze the lever and find nothing there.
Old Jul 5, 2011 | 09:49 AM
jlandis874's Avatar
jlandis874
The gasket is not sold separately, you'll have to buy a new cap for the MC that has a the new gasket attached to it if its not covered under warranty, which it should be. it cost me $30 for a new one. Had the same probably in March on my 09 Fatboy.
Old Jul 5, 2011 | 10:14 AM
Sgt_Jim's Avatar
Sgt_Jim
The gasket is sold separately, my dad just put 2 new ones on his front and rear master cylinder. and yeah, make the dealer do it, otherwise it's just a gasket. A friend of mine, who builds bikes, coincidentally was just talking with me about this.. at the maximum you can remove the lid of the master cylinder 4-5 times before you need to replace the rubber gasket, since it never compresses the same way each time you tighten it. Quick fix if you want to do it yourself
Old Jul 5, 2011 | 10:55 AM
jlandis874's Avatar
jlandis874
My mistake. I was told that they stopped selling the gasket separately when I bought mine.
Old Jul 5, 2011 | 03:06 PM
wiktor's Avatar
wiktor
Thanks Guys! Called the dealer and it's going there in the morning.
davidsdad
Sep 9, 2014 07:08 AM
fatboy slim
Apr 9, 2014 08:41 PM
jisananimal
Nov 30, 2011 08:19 PM
TurkeyRun
May 8, 2009 12:12 PM
mikeshog
Mar 22, 2008 04:27 PM
