2005 Softail with no spark-HELP!
Old Jul 12, 2011 | 09:10 PM
ScottyZ429's Avatar
ScottyZ429
6th Gear
Default 2005 Softail with no spark-HELP!
2005 Softail Standard with no spark. Rode one day, shut it off and no start next day. Cranks over but no spark. Checked the crank sensor, coil, bank angle sensor, and even the ECM. I even went as far as to swap out the ECM, coil, bank angle sensor, and crank sensor with ones from my buddy's softail that is same year and model, still with no luck. No DTC's are present. Tested all parts in question with a DVOM and all meet specs in my manual. Checked for spark with plugs installed in the heads and used a spare set of plugs installed in wires and grounded to the heads, all with no luck. Any help would be appreciated.
Old Jul 12, 2011 | 10:07 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Did you try different plug wires? Different plugs?
Drew
Old Jul 13, 2011 | 06:32 AM
ScottyZ429's Avatar
ScottyZ429
6th Gear
Tried different wires AND plugs... no luck.
Old Jul 13, 2011 | 10:53 AM
kkiley's Avatar
kkiley
Well, logic says it's time to look into the wiring. Something is telling the bike not to fire. It's tedious but the wiring harness can be broken down in sections. A broken wire, switch not working, something unplugged....I feel for ya, took me 3 times to find the wire that feeds my bank angle sensor was broken internally and kept shutting the bike off.
Old Jul 13, 2011 | 11:33 AM
ScottyZ429's Avatar
ScottyZ429
6th Gear
Figured it would be my luck that it'd be the wiring. LOL. Not looking forward to this step.
Old Jul 13, 2011 | 12:20 PM
JakesDad1's Avatar
JakesDad1
How about the kill switch???? Nope, guess not if its turning over. Good luck
Old Jul 13, 2011 | 12:49 PM
ScottyZ429's Avatar
ScottyZ429
6th Gear
If the kill switch was bad, wouldn't that not let it crank over either? It cranks but no spark.
Old Jul 13, 2011 | 02:25 PM
kkiley's Avatar
kkiley
Scotty, I have been there, it seems daunting at 1st. But once you get the tank off and pull the harness out where you can get at it, it's not that bad. It's all plug and play, so you aren't going to hurt it worse, just some time spend with a VOM. I really think something came unplugged and it won't be as bad as you think.
Good luck.
Old Jul 17, 2011 | 07:40 PM
ScottyZ429's Avatar
ScottyZ429
6th Gear
Come to find out, it was a broken wire in the main plug on the ecm. Back up and running. Thanks for the help.
Old Jul 17, 2011 | 09:16 PM
oct1949's Avatar
oct1949
How'd U find that out....???????
bobby5998
Nov 29, 2017 06:29 AM
pavin
Jul 28, 2017 03:53 PM
twincam47
Jun 19, 2014 01:27 PM
M&P340
Oct 17, 2012 12:11 AM
ScottyZ429
Jul 17, 2011 07:41 PM
