Clutch and throttle cable lube
Old Jul 13, 2011 | 10:17 AM
aaron8771's Avatar
aaron8771
Default Clutch and throttle cable lube
05 Night Train. Need some lube in my cables. Don't have any cable lube here. But I got a nice can of silicone spray lube. Would this be acceptable to use on my cables? Thanks
Old Jul 13, 2011 | 11:38 AM
oldgeezer's Avatar
oldgeezer
I use Dry Slide. It has a long tube that will fit well into the cable housing. The silicone will probably work OK if you can get it to flow down the cable housing.
Old Jul 13, 2011 | 11:55 AM
kzoo's Avatar
kzoo
I just did this to my 04 Heritage. Clutch was getting harder to pull. I used a Monoject 412 syringe that I always have around, sprayed the silicone into the cap of the can, sucked it out with they syringe and inserted the fine point of the 412 into the cable. Slowly inject the lube. A couple of times and it was fine.
Old Jul 13, 2011 | 03:00 PM
Weevil's Avatar
Weevil
Cable lube is about halfway down the page.
http://thp.yuku.com/topic/123/t/Tip-of-the-Week.html
c50plus
May 23, 2016 08:52 AM
SnoRider
Dec 14, 2015 08:05 AM
barb6663
Jul 4, 2012 08:09 PM
2black1s
General Topics/Tech Tips
Nov 25, 2010 03:46 PM
40 Knuck
Mar 9, 2010 08:04 AM
