Harley Springer 4.5 Deg Rake Kit
Old Apr 19, 2013 | 05:23 PM
  #101
MEATsicle's Avatar
MEATsicle
This sounds like its definitely NOT a bolt in kit which is not how it's advertised. That sucks! I would have considered this kit, but I'm not a machinist nor do I have a lathe. If I did, I would have made my own kit from scratch. Sounds like the verdict on this kit is that it is crap!
Old Apr 28, 2013 | 09:57 PM
  #102
scooter223's Avatar
scooter223
The kit is actually very good and very well made. The modified geometry of the stem is perfect, unfortunately the reality of it is, there really isn't anything made that's absolutely perfect for thousands of bikes produced. I would certainly suggest this kit, and it was truly pretty easy once I was able to figure the variables that I wasn't aware of from the start. That's the reason I felt the need to post such a long description of the install. If you do decide to go though with it, feel free to pm me and I will tell you everything that I know in order to help out.
JS
Old Apr 28, 2013 | 10:00 PM
  #103
scooter223's Avatar
scooter223
Originally Posted by Ubnvs
Scoot,
Did you do the 4 degree kit?
Yes, it's actually advertised as a 4.5° kit, but who knows...
JS
Old Apr 29, 2013 | 06:44 AM
  #104
brettnbama's Avatar
brettnbama
What model bike you have scooter?
Old Apr 29, 2013 | 07:58 PM
  #105
scooter223's Avatar
scooter223
2004 fxsts
JS
Old Apr 29, 2013 | 09:05 PM
  #106
back again's Avatar
back again
How about some after shots scooter.I'm looking at doing the 04 and the 96.
Old Apr 30, 2013 | 09:39 AM
  #107
scooter223's Avatar
scooter223
Here ya go...
JS
Old May 3, 2013 | 02:53 PM
  #108
MEATsicle's Avatar
MEATsicle
Well, I did it. I installed the 7.5 degree rake kit on my 2009 Crossbones. It looks good and operates and rides great! A couple things tho...
Do not even bother attempting to remove the stock stem from your springer with a hammer. I banged on it with a sledge for a long time and got nothing. My buddy is a mechanic at a Toyota dealer so I brought it over to him and we pressed it out with a 20 ton press. Even then it took a bit. We thought it was going to snap.
FYI, the stem goes out by pressing from the top through the bottom.
One of the problems I ran into after installing the whole kit was that the top of my springer rubbed the neck casting. I called Vulcan up and they told me that each casting is different at Harley so that happens from time to time. There are three solutions, space it out with washers, grind a groove in the neck or grind some material off of the springer. I ground my springer first but that wasn't enough so I ground some material off of the neck casting. I then touched both up with black touch up paint from the local auto parts store and you can't tell I did anything. That and it's hidden anyway. Now, no problems.
I have put a couple hundred miles on it since install and so far no problem.
I recommend the kit. It's a pretty easy install to do and a relatively cheap mod.
One last thing, my bike already had a Burly 1.5" lowering kit on it. The Vulcan kit states that it will drop the frontend 1.75". I didn't notice that much of a drop. Unfortunately I didn't take before and after measurements.
Here are a before and after pic...
Attached Thumbnails Harley Springer 4.5 Deg Rake Kit-img_5155b.jpg   Harley Springer 4.5 Deg Rake Kit-img_5307b.jpg
Old May 3, 2013 | 04:18 PM
  #109
Scott Hall's Avatar
Scott Hall
Looks great MEATsicle! What size tire & wheel are you using? Who makes that cool rotor?
Old May 3, 2013 | 05:01 PM
  #110
MEATsicle's Avatar
MEATsicle
The Tire is a Metzeler 140/70-21 on a Black Bike 21x3.5 40-Spoke Wheel.
Brake Rotor is a Wilwood (non-floating).
