I've put about 400 miles on the bike since it came off the jack this winter.
I'm planning on heading to Sturgis in a week. That means 5,000+ miles of hot highway miles.
I was looking at the situation on Saturday and decided those bolt heads were just too close to the side wall (1/8" side cleanance). I took the entire back end off, put a heavy clamp where the sissybar attaches to the swing arm, and then pushed the sissy bar wider at the fender with a hydraulic bottle jack. Now I just have to put it back together tonight. Only problem is that now the top clearance to the tire will be closer. Hope it works.
Like everything I have done to my bike, there were issuse...........
The fender was close on the sides. So I spread the sissybar and fender. That made the fender ride on the tire on top (it shrunk the fender radius).
To solve that problem I extended the "legs" of the sissy bar.
I welded-on tabs that made the sissybar 1/2" taller. But that screwed-up the geometry of the luggage rack. So I had to weld-on tabs to the luggage rack to make it long enough.
The bottom line is that everything is working. I need to cut the u-bolts to size, but its ready to ride again without worrying about the fender clearance.
The seat won't be an issue... I have put almost 5K on my Original Solo Seat this summer and love it. By the time you need to fuel it is time to get off the seat for a few minutes anyway. 600 miles a day were no problem!
How you doin with the jockey shift. I picked mine up quickly but still occasionally kill it on starts from red lights.
