confused
Old Jul 25, 2011 | 08:23 PM
boss man's Avatar
boss man
Stage I
Default confused
new to the forum and harleys,might be a stupid question recently purchased a 2011 fat boy lo and a set ofsoftail leather bags fa boy styling and can't figure out how to break the bolts loose to mount them.don't want to strip them out
Old Jul 25, 2011 | 08:54 PM
dcgray2's Avatar
dcgray2
Make sure you are using the correct size torx bit! Heat them up one at a time. Sticking a soldering iron in the end works.
You need to break the red loctite. Also use red locktite when you put them back on.
Old Jul 25, 2011 | 08:55 PM
tmitchellof PG's Avatar
tmitchellof PG
I broke mine loose, on my 2005, using a #45 Torx bit and a cheater bar. Make sure you are using the right size bit for the bolts, I know on the 2005 some owners mistaken use an allen wrench and strip the heads. You may also need to heat the bolts up, with a heat gun or hair dryer, to loosen the Loctite before they will break loose. I was prepared to do that, but I didn't have any problem with my long handle cheater bar. Also on my 2005, I had to squeeze a finger between the fender and the tire to hold the steel strap with the nut plate and wire holder in place while I removed the original bolts and put in the new ones.
I don't know if your 2011 is the same setup as my 2005.
Tom
Edit: I changed the Torx size in the above post, for some reason I was thinking about the primary inspection cover
Old Jul 25, 2011 | 09:55 PM
HoggyMtnBreakdown's Avatar
HoggyMtnBreakdown
The strut bolts are Torx size T45 for 2007 and later Fatboys, I believe. Don't use the L-Torx wrenches that came with the bike. Rather get a T45 bit (or set of all sizes) for your 3/8 socket wrench. This will allow you to get even leverage on the bolt without stripping it out.
Old Jul 26, 2011 | 05:17 AM
oct1949's Avatar
oct1949
Make sure U have the correct size and put pressure straight in on the bolt as U loosen it, and don't let the torx head roll out of the bolt head. Thats how most guys round out the bolt heads.
Old Jul 26, 2011 | 06:22 AM
Kojax's Avatar
Kojax
Smile
i have the fatboy lo i put the new chrome torx bolts on . they came off very easy size torx is 45
Old Jul 26, 2011 | 09:42 AM
dcgray2's Avatar
dcgray2
Originally Posted by tmitchellof PG
I broke mine loose, on my 2005, using a #27 Torx bit and a cheater bar. Make sure you are using the right size bit for the bolts, I know on the 2005 some owners mistaken use a #25 Torx and strip the heads. You may also need to heat the bolts up, with a heat gun or hair dryer, to loosen the Loctite before they will break loose. I was prepared to do that, but I didn't have any problem with my long handle cheater bar. Also on my 2005, I had to squeeze a finger between the fender and the tire to hold the steel strap with the nut plate and wire holder in place while I removed the original bolts and put in the new ones.
Tom
I did my bolts one at a time and didn't have any issues with the steel strap/nut plate inside the fender.
Old Jul 26, 2011 | 09:52 AM
Sgt_Jim's Avatar
Sgt_Jim
that red loctite is a pain in the tuchus.
Old Jul 27, 2011 | 08:26 AM
metaphysician's Avatar
metaphysician
I had the same trouble. A 24" breaker bar and the right torx bit is the secret.
kainvamp
May 5, 2021 02:37 PM
Yeti71
Jun 18, 2019 04:03 PM
Jackpoticorn
Aug 25, 2014 12:23 PM
SgtMic
Apr 16, 2010 09:11 PM
stic2it
Dec 10, 2009 03:08 AM
