Ride wright wheels not happy!
Old Aug 7, 2011 | 05:02 PM
bigdog bigdog's Avatar
bigdog bigdog
6th Gear
Angry Ride wright wheels not happy!
Got them in and the rear wheels rotor dont fit the bolts are wrong and the hub threads are to big for the rotor very pissed off
Old Aug 7, 2011 | 05:29 PM
Malingerer's Avatar
Malingerer
The rotor doesnt fit on the hub? Or it doesnt fit because the bolts are too small (which will make the threads too big.Sounds like you just need bigger bolts.May be they sent you 2 sets of hardware for the front wheels?
Old Aug 7, 2011 | 05:40 PM
bigdog bigdog
6th Gear
The rotors are the same the hub threads are to big the roror holes to small
Old Aug 7, 2011 | 05:47 PM
Malingerer's Avatar
Malingerer
Did you get both front and rear wheels? The rotors look the same but they are different? The front has smaller holes and smaller bolts. The rear has bigger holes and bigger bolts. Sounds like you may be criss crossing them(using the front on the rear) Or they sent you two fronts .Instead of 1 front 1 rear.
Old Aug 7, 2011 | 06:20 PM
bigdog bigdog
6th Gear
Rotors all the same bolts the same
Old Aug 7, 2011 | 06:28 PM
jreichart's Avatar
jreichart
Sounds like you got 2 front rotors with 2 sets front hardware. The front uses 5/16" and the rear uses 3/8" hardware. At least that's the way it is with stock.
Old Aug 7, 2011 | 06:42 PM
Malingerer's Avatar
Malingerer
Yup what I stated in post #4.Sounds like they sent you 2 front rotors and hardware.Easy fix though bro.Maybe they will over night you a rear rotor and hardware.
Old Aug 7, 2011 | 07:29 PM
Green Hornet's Avatar
Green Hornet
Yup get new ones. The company will fix it for you.
Old Aug 7, 2011 | 10:03 PM
nikonf8's Avatar
nikonf8
Default problems
another ride wright problem take a good look its seems to be happening on a daily basis now. who do they have working for them. these things can all be avoided if they had some quality control seems like they are becoming one of the companies who are living on past reputation. yes its great that they will make it right but at your expense meaning another delay in game. chit happens but this stuff can be avoided very easy measure twice cut once kind of the same idea. double check all orders maybe even three times its definitely costing them money any way you look at it
Old Aug 8, 2011 | 09:16 AM
bigdog bigdog
6th Gear
On top of this I order my tires too from them and they put them on backwards after I put my dynabeads in them another 40 bucks gone. I had to reorder.
