Rear brake light switch
Old Sep 13, 2011 | 07:20 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Take a pic with your dell phone and get one that looks the same. I can't remember what it fits.
Drew
Old Sep 13, 2011 | 08:43 AM
Ash16's Avatar
Ash16
Had the same thing happen to me a few weeks ago. Autozone carries them. You don't have to have a part number. Tell them what it's for and the computer tells them the part number. I went in with part numbers and their computer couldn't pull anything up. The switch that they carry is bigger than the harley one but fits and works perfectly. It is hidden by my exhaust anyway. +1 on the plumbers tape to ensure that it doesn't leak.
Old Oct 23, 2011 | 08:14 AM
NickD's Avatar
NickD
Don't know if this applies to you guys but . . .
Harley-Davidson Recall.
October 23rd, 2011
Rear Brake Switch And Lamp On 09-12 Touring And Trike Models
Potential Number of Units Affected: 250,757. Summary: On certain models year 2009-2012 Touring, CVO Touring and trikes manufactured from June 6, 2008 through September 16, 2011, the rear brake light switch may be exposed to excessive heat from the exhaust system. Consequence: The excessive heat may cause the switch to not activate or activate the brake lamp when no brake is applied and/or cause a brake fluid leak at the brake light switch affecting rear brake performance. Either condition may increase the risk of a crash. Remedy: Harley-Davidson will notify owners and dealers will install a rear brake light switch kit, free of charge. The safety recall is expected to begin on or about October 31, 2011. Owners may contact Harley-Davidson at 414-343-4056.
http://www.cyrilhuzeblog.com/2011/10...-trike-models/
Old Aug 8, 2012 | 05:02 PM
PierreG's Avatar
PierreG
My '04 Sporster XL 1200 rear tailight requires me to almost stand on the rear brake pedal to get the light to come on. The brakes pads are new, the light has functioned with just tapping the pedal (like it's supposed to) until a few days ago.
I bled the brakes, and the brakes are working well. Your thoughts appreciated. Thanks.
P
Old Jun 28, 2018 | 08:09 AM
cgcss1's Avatar
cgcss1
1st Gear
Default 2005 Softail Rear Brake Light Switch Removal
So my rear brake comes on with the hand brake but not the pedal. I jumped the two terminals on the rear brake light switch and the brake light comes on. Sooooooo, how do you remove this switch? It is original and it shaped differently that a socket does not seem to fit almost as if there is a specialty tool for it. There is absolutely no room to get in there with pliers, vice grips, etc because of the Vance and Hines exhaust.
Is there a special socket that will fit?
Old Jun 28, 2018 | 09:55 AM
Tom84FXST's Avatar
Tom84FXST
Originally Posted by trekez2
The pressure switch I discovered was a new banjo type (#72026-08) and was back ordered for several months.
They make an adapter so you can use the "regular" more common switch.
I have changed dozens of the old style switches without having to bleed the brakes.
Old Jun 29, 2018 | 07:06 AM
RocketRocker's Avatar
RocketRocker
Man typed in this thread like 7 years ago!! So for the front brake lever, if they are after market levers pull the lever out and grind the end that comes in contact with the switch...your lights are more than likely on cause your brakes are slightly engaged. The 5/32 spacer is mentioned in the service manual and makes sense, I usually just make sure I can jiggle the lever (you don't want it tight...so it's not engaging the brake).
If that don't work, trying to fix the problem without busted fuses will take awhile. Recommend go to Badlands and get there plug n play step down inverter thing and this will resolve the 6v to 12v electrical issues that are known for on the Rocker Cs. Hope this helps.
Old Apr 25, 2021 | 01:57 AM
Michael Rogers's Avatar
Michael Rogers
Spoiler
I have the same problem on my 02 deuce, I was wondering if you resolved yours,, I can't get no kind of wrench anywhere that works. I wonder if I'm going to have to drop the brake line beneath it to get a wrench on it?
Old Apr 25, 2021 | 12:42 PM
Tampa Fatboy's Avatar
Tampa Fatboy
Common for the rear brake pressure switch to go bad, Accel has a replacement at most auto parts, as Drag Specialties, and HD. The front brake reservoir gets gummed up and wont let the plunger release not allowing the switch to work, which means rebuild or buy a new reservoir.
ORradtech
Aug 27, 2016 09:39 PM
MachU
May 30, 2014 11:50 AM
maddghost
Nov 19, 2012 04:52 AM
Green Machine 04
Oct 5, 2010 02:34 PM
Milwaukee 1
Aug 20, 2010 11:17 PM
